QA1 shocks question.
Old Mar 30, 2006 | 05:27 PM
94NDTA's Avatar
I have adjustable QA1's front and back.
What is the best set up for the strip for these? Do I want at harder setting for the rear and a softer setting for the front?
What is recomended?
Old Mar 30, 2006 | 06:46 PM
DarkHorse's Avatar
Re: QA1 shocks question.
To be quite honest every setup will be different. It's best to make a couple of passes then make a change, couple of passes, take notes, repeat process.....
Track conditions, vehicle setup, temp, etc.... will all play a factor. Sure you can get someone elses setup info but don't be surprised if it doesn't apply to your car.
Old Mar 30, 2006 | 11:54 PM
shady93z's Avatar
i always started with 0-2 up front and 4-5 out back.
Old Mar 31, 2006 | 09:53 AM
Ditto.... turn the fronts to "1" to start, and leave the backs at "6". Try a pass or two. Then try moving them a step or two at a time until you find the sweet spot.
Old Mar 31, 2006 | 09:51 PM
94NDTA's Avatar
Thanks guys.
Mar 13, 2016 03:37 PM
Bigfatrat
Parts Wanted
Oct 16, 2015 04:48 PM
football4life
Oct 4, 2015 07:48 AM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
