UMI 3 Point Subframes
Old Mar 28, 2006 | 08:49 AM
Grims's Avatar
I am thinking about getting the UMI 3 point, with the tubular brace mounted torque arm.
My questions are.
1. Will I have any clearance issues hooking this up with pacesetter long tubes with the Y pipe.
2. Is it really going to make much a difference with traction using aggressive street tires?
Also, does UMI offer us any kind of discount?
Old Mar 28, 2006 | 11:48 AM
danhr's Avatar
Re: UMI 3 Point Subframes
i'm down for a group purchase if you cordinate one
i dont know if umi does group purchases though...
Old Mar 28, 2006 | 01:10 PM
mook99TA's Avatar
both of those mods are great for our cars. Get the adjustable tq arm so you can adjust for better traction and as far as SFC's they are a must.
Old Mar 28, 2006 | 02:20 PM
Grims's Avatar
I am looking at this torque arm, that connect to the 3 point http://www.umiperformance.com/2202.aspx
I am wondering though, how can traction be as good as the stocker, with the engine and tranny not torquing down onto it?
Old Mar 28, 2006 | 04:26 PM
MPB70350's Avatar
It is connecting to a solid point not the transmission, which i think is a horrible design especially the piece of junk bushing. Also it is stiffer and allows you to adjust your pinion angle. The stock torque arm is not being torqued down by the engine and transmission.
Old Mar 28, 2006 | 04:32 PM
2000GTP's Avatar
I would contact UMI first about the torque arm. With my Spohn arm for example, they have two different styles, one for a stock style exhaust and one for long tube headers. They will tell you for sure if it will work with your application. I'm pretty sure they run specials on ls1tech.com from time to time so if you are a member on there.. It should give you a little more bite on street tires, but a set of grippy tires will be your best traction mod.
Old Mar 30, 2006 | 02:54 PM
1quickTA's Avatar
I cannot say anything about the torque are fitment, but I do have the UMI 3 pt SFCs with Pacesetter LTs and Y-pipr and there is plenty of clearance.
Old Mar 30, 2006 | 03:10 PM
Grims's Avatar
how big of a difference did you notice in the setup?
68camaroboltz
Oct 5, 2015 01:46 PM
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
