LT header install. Help!
Old Mar 27, 2006 | 12:10 PM
Rage's Avatar
Im installing the Hooker Supercomp LT's on my thirdgen LT1 and am having some problems. The header was first making contact on the knock sensor, so I moved the knock sensor to the driver side, that took care of that, but now, Im making hard contact on the A-arm mount. Has anyone else ran into this problem? Hooker said these headers are made for my car, but I dont know. Please help.
Old Mar 27, 2006 | 12:13 PM
89Vert's Avatar
Re: LT header install. Help!
motor mounts worn?
a buddy of mine put long tubes on his '88 Iroc and had to use a starter off an LT1
Old Mar 27, 2006 | 12:53 PM
Z28SORR's Avatar
These are big headers and some contact is almost inevitable. My 84 has solid motor mounts so I've had fewer problems then most but they still made contact on the Lakewood Bell Housing. A little bending, beating and grinding usually takes care of this. You'll definately need a mini-starter.
Old Mar 28, 2006 | 01:39 AM
AutoRoc's Avatar
I used new poly mounts first off.
Hooker LT's I have contacted the brake lines on both sides of the engine when they run along the top of the K member. Bending them fixed that but they're still close.
Uncomfortable close to the A-Arm on the driver side and big contact on the pass side. A Sawzall and carbide bits were used to take off the excess meat that isn't needed on the a-arms.
Also had to carbide grind the weld on the backside of the K member because they touched there a little also. PITA but probably very worth it over shorty headers. Mufflex Y-pipe also touches Spohn cross member...Sawzall again.. Goodluck!
Old Mar 28, 2006 | 09:14 AM
RedIrocZ-28's Avatar
Denny, you don't by chance have any photos of your modifications do you? I just ordered a set of the Hooker SuperComps. This car... ugh... killin the bank account.
Old Mar 29, 2006 | 04:58 PM
Rage's Avatar
So, you just cut the A-arm knuckle? did you weld anything back in place? that looks like it is somewhat structural to me. The rounded edges gives it strength I believe. I could be wrong as I often am.
Old Mar 30, 2006 | 06:19 PM
Rice Killer87's Avatar
Smack them with a Ford tool,aka hammer.
I had beat the F outta my hooker supercomps
Old Mar 30, 2006 | 08:38 PM
ws6transam's Avatar
I'm experiencing the same contact as Denny did and I've got some poly motor mounts that should take care of a lot of the problem. Thanks for the tips Denny I will tune up the sawzall while I am in there. BTW, Andris Skulte now has a Hooker LT specific crossmember available on his website, www.skulte.com
It's for T56 retrofits.
Old Apr 1, 2006 | 11:32 PM
AutoRoc's Avatar
No pics of the mayhem but it's in a location that's hard to see unless the engine is out of the car.
Cutting some excess steel off of the A-Arm area looks safe to me. It's not load bearing or stressed or functional in any way.
Bolt disk
Removed 1" or so of steel here--> ==O======]=} <--Wheel
(A-Arm frontal view above)
Old Apr 5, 2006 | 11:59 AM
Jim D's Avatar
Hey guys, I put an LT4 in and am running into the same challenges. I have called Hedman and found out that "the IROCs have larger A-arms and the frames are different too"...Hedman's office in GA (racing division) said they have a car in the yard they want to use to build up a set for this application, but he had 10 cars in front of that to do first. Their CA office just told me they didn't know if anything would get past the larger A-arms, they weren't built for that application.
I didn't know that there was such a difference between the cars. Maybe this is why some people have no problem putting headers in while other people are cursing the whole time. Dropping headers into an RS may be easier than an IROC.
Anybody with more experience, please add to this thread. I would really like to find out which headers work with our frames!
Old Apr 6, 2006 | 10:07 AM
Z28SORR's Avatar
One solution may be to get the Global West or BMR A-arms.
Old Apr 8, 2006 | 09:50 AM
Chrome383Z's Avatar
I've never heard of a difference in A-Arms... ???
Old Apr 8, 2006 | 12:03 PM
Rottluver's Avatar
I have never heard of IROCs having different frames either.......the IROC package was just suspension/appearance.....no need to alter the frame that I know of.............but I suppose anything is possible.
Old Apr 8, 2006 | 12:34 PM
conlinj's Avatar
The a-arms were the absolute same iroc to iron duke 4 cyl. Iroc's had a wonder bar that's about it for frame modifications.
Old Apr 8, 2006 | 12:40 PM
Rottluver's Avatar
That's kinda what I thought........but far be it from me to say someone has bad info.
Oh yeah, what is a wonder bar?
