MSD 6A benefits?
Old Mar 23, 2006 | 09:25 PM
TRSCobra's Avatar
MSD 6A benefits?
I just bought one of those MSD 6A ignition systems. I'm just curious about any performance/driveability gains I can expect...
Mods are in my sig.
Old Mar 23, 2006 | 10:31 PM
IHI's Avatar
IHI
Re: MSD 6A benefits?
If your existing ignitionis working properly you will not see any performance gains. Many claim it smoothed up the idle a bit or made the car easier to start, but I promise you will be no faster if your old ignition was upto snuff-been proven at tracks across the country time and again.
Old Mar 24, 2006 | 07:16 AM
87DJP2001's Avatar
None, also may be the start of electical problems after you install it.
Old Mar 24, 2006 | 08:15 AM
Evil TA's Avatar
not really sure why you say that....
i've used a 6, 6a and now a dig 6+ box - the 6a lasted me 7 years before i finally just upgraded... still worked fine
Old Mar 24, 2006 | 10:32 AM
IHI's Avatar
IHI
Anything mass produced is bound to have bad apples here or there, just as how/where it's installed will also lead to possbile problems.
Our group has 12 6AL's with the newest being 4yrs old and none have ever given a hint of problems to date.
Old Mar 25, 2006 | 06:02 PM
TRSCobra's Avatar
Well, I got it installed... The driveability is better, but there's a little hesitation as soon as you give it gas. Probably needs to be re-timed.
While the rotor was off, I noticed the one spring for the mechanical advance weights was off. Its probably been like that since I bought the distributor, as that was the first time I had the rotor off.
Old Mar 25, 2006 | 07:55 PM
89TramsAmGTA's Avatar
I did back to back dyno tests and maybe a 2RWHP gain. Bottom line is you won't notice it.
Old Mar 26, 2006 | 09:32 AM
2000GTP's Avatar
It might smooth out your idle a little bit, that is about it though.
Old Mar 26, 2006 | 01:44 PM
anthony714's Avatar
not worth the coin...better off bolting a bottle up...stock ignitions make more than enough spark for a street engine
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
football4life
Oct 4, 2015 07:48 AM
Z Power
Sep 19, 2015 11:19 PM
Daluchman1974
Sep 11, 2015 06:12 AM
