Heater Core Help
Old Mar 14, 2006 | 10:08 PM
6SpdLT1Z's Avatar
Heater Core Help
Ok... I'm *FLUSHING* my heater core this weekend.
I think I will use Asainsinsations method.
First question:
These are the locations of the hoses i should remove, right?
Now one of those can I hold over the radiator and open the bottom of the radiator? Then have a friend slowly pump water into the other one? or should I pull the other hose down past the opti and hold it over a drain on the bottom of the car? is that all there is to it?
Thanks.
Also I need 7 quarts of Coolant, 7 Quarts of water, and 1.5 Quart of 50-50 right?
Old Mar 14, 2006 | 10:14 PM
shoebox's Avatar
Re: Heater Core Help
Why do you need to bleed the heater core? Use the bleeder screws to remove air from the system.
Old Mar 14, 2006 | 10:15 PM
6SpdLT1Z's Avatar
Sorry, I meant flush.
Old Mar 15, 2006 | 09:25 PM
6SpdLT1Z's Avatar
Ttt
Old Mar 17, 2006 | 08:27 PM
6SpdLT1Z's Avatar
Ttt
Old Mar 17, 2006 | 11:15 PM
MyShibbyZ28's Avatar
Well I can't help you on the flush since I did mine right at the firewall, but 7 quarts of water/7 of coolant, plus the 1.5 of 50/50, will still end up being the same. You could just put 7.75 coolant + 7.75 water and get the same thing. The back of the bottle should have a diagram of what the best mixture is.
Old Mar 18, 2006 | 02:43 AM
smoknta's Avatar
Just follow both hoses from the firewall to the water pump and remove them. Put a garden hose to one side and put the other end in a bucket. Then reverse hoses, to flush it the other way. When your satisfied it is flushed good, put the hoses back on. Fill the radiator back up and bleed the air out.
Old Mar 18, 2006 | 02:47 AM
6SpdLT1Z's Avatar
Thanks.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
