Mcleod twin clutch set up question.
Old Mar 8, 2006 | 06:15 PM
supercharged87's Avatar
I'm looking into getting the Mcleod twin clutch set up, but I have 4 questions. What exactly comes with the kit? Also I have an internally balanced 383, I'm running an A4 with the weights knocked off the flexplate, does Mcleod have a kit with a flywheel that will work with this engine? If so whats the part number? And finally, where does everyone buy theirs at? Thanks alot in advance.
Old Mar 8, 2006 | 07:49 PM
OBE1 95Z28's Avatar
Re: Mcleod twin clutch set up question.
McLeod can answer your first 3 questions. I believe the newer kits come with the flywheel, pressure plate, clutch disks and center plate, throw out bearing and adjustable master cylinder. The flywheel has a removable weight to allow you to run a neutrally balanced flywheel.
BPS
9
Mar 5, 2015 10:51 PM
HectorM52
Jan 30, 2015 11:08 PM
RichJ
Aug 11, 2002 10:14 PM
