Headlight pattern question
Old Feb 15, 2006 | 12:30 PM
Honda Hunter's Avatar
I'm going to do the low/high beam same time mod and I was wondering if I put FF75 driving lights in place of the low beams and ff75 fog lights in place of the high beams how do you imagine the patter woul look? Im thinking it will cover more of the road. Just want to see if its worth it or not to try.
Old Feb 15, 2006 | 12:42 PM
Z95m6's Avatar
Re: Headlight pattern question
The fog lights have a very very short pattern but its really really wide. I'd personally just run the fog lights in the fog light position. At least thats what i did. I suggest just always run with your fogs on especially 2 lane roads the hellas have such a wide pattern you'll be lighting up farmers fields as you drive. I have my low beams aimed a little lower than stock and my high beams aimed much higher than stock. That way when you flip the highs on you can see a mile down the road.
Old Feb 15, 2006 | 12:52 PM
Makes sense. Thanks for the info. I cant wait to get these on.
Old Feb 15, 2006 | 12:56 PM
Z95m6's Avatar
You can go a head and try it out though the great thing about the hellas is they all are the same size so they'll inner change. Its just its kind of a pain to put lights in the fog holes so you don't really want to be removing them a lot. So you can easily try your fog high beam idea first and see what you think, before you put the fogs completely in place.
ChrisFrez
Feb 22, 2015 08:47 AM
ChrisFrez
Feb 15, 2015 08:12 AM
94Z28LS1toLT1
Feb 10, 2015 10:19 AM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
CaRParts102
Dec 6, 2014 08:45 AM
