adj. lower control arms and relocation brackets
Old Feb 12, 2006 | 05:19 PM
luckyou03's Avatar
Can someone tell me the length from center of bolt to center of bolt of the stock lower control arms? Also I have relocation brackets and I was going to use the lowest hole. Do I still use the stock lca length or make it longer, shorter? thanks
Old Feb 12, 2006 | 06:16 PM
Greed4Speed's Avatar
Re: adj. lower control arms and relocation brackets
Should be the same length if they were properly installed. The only time you need adj. LCA's are when you need to move the wheels in the wheelwell.
Old Feb 12, 2006 | 11:32 PM
luckyou03's Avatar
already threw mine out, and I have nothing to go by.
Old Feb 13, 2006 | 03:35 PM
94badrag's Avatar
go to this thread on page 3 in this section and check out the link. it tells the measurement you ask for.
LCA Install Write Up???
Old Feb 13, 2006 | 06:50 PM
luckyou03's Avatar
cool I found it, 19 1/4 for future reference.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
thenewkid
Apr 12, 2015 07:42 PM
PaulN64
Aug 8, 2002 05:39 AM
PaulN64
Aug 7, 2002 06:17 PM
