Will a D1 crank pulley work with a F1 head??
Old Feb 11, 2006 | 03:52 PM
streetbad's Avatar
Cool Will a D1 crank pulley work with a F1 head??
Thank You
Old Feb 11, 2006 | 04:46 PM
markinkc69z's Avatar
Re: Will a D1 crank pulley work with a F1 head??
Do you mean D1SC? if so then yes.
Old Feb 12, 2006 | 09:45 AM
streetbad's Avatar
Question Re: Will a D1 crank pulley work with a F1 head??
No, The pulley I have is for a oil line type D1. What is the difference in crank pullies between a D1 and a D1SC?
Old Apr 9, 2006 | 09:25 AM
streetbad's Avatar
Is there a diference in offset? Would a spacer change line this up? Do I need to get a pulley for a D1SC?
Old Apr 10, 2006 | 10:18 AM
KS91Z28's Avatar
There is no difference in offset, just diameter. You just need to calculate your max impeller rpm to make sure you don't overspin the blower.
Old Apr 10, 2006 | 05:20 PM
streetbad's Avatar
Thank You KS91Z28!!! The Crank pulley I have is 7.65 dia. What is the diameter of the crank pulley for a D1SC?
Old Apr 11, 2006 | 01:34 PM
KS91Z28's Avatar
For most kits, it's 7.65, but ATI also has a 8.5" crank pulley available.
Old Apr 11, 2006 | 02:38 PM
95 Z/28 LT1's Avatar
Super Moderator
I have one of those and it's huge. It comes pretty close to the swaybar.
HectorM52
Jul 30, 2017 11:46 AM
SpeedJunkee
Jan 27, 2015 10:02 PM
Queens94z28
Nov 20, 2014 06:03 PM
1LEThumper
Jul 14, 2003 12:45 PM
Brian-94TA
Jul 31, 2002 02:52 PM
