timing chain
Old Feb 7, 2006 | 07:48 AM
rique71's Avatar
timing chain
good morning guys , how hard is it to change the timing chain on a 98 z?
Old Feb 7, 2006 | 11:50 AM
Greed4Speed's Avatar
Re: timing chain
Not real easy but not horrible. While you're there you might as well change the cam and upgrade the oil pump. Get an LS2 chain. They're much beefier than the LS1, fits right on the cogs and costs ~$35.
Old Feb 8, 2006 | 11:22 AM
Kataklysm's Avatar
Re: timing chain
You'll need to pull the water pump and crank pulley off to get the timing cover off. I'm trying to remember if anything else is in the way of the cover or not. If there isn't you'll be looking at the oil pump and timing chain at this point. So thats basically all the work besides removing the chain itself, I'd upgrade oil pumps while being in there.
Old Feb 10, 2006 | 10:49 AM
rique71's Avatar
Re: timing chain
thanks 4 the info guys
Old Feb 10, 2006 | 03:19 PM
KPI's Avatar
KPI
Re: timing chain
Oil pump has to come off to change the timing chain, so it's probably a good idea to replace it. The bolt holding the pickup tube and the o-ring can be tricky. Be careful.
Old Feb 11, 2006 | 06:17 PM
CarrotcarZ's Avatar
Re: timing chain
can I just use the ls2 chain or do i have to change the whole assembly?
Old Jan 14, 2007 | 07:29 AM
faSStcars's Avatar
Stupid question I know. It doesn't require a puller to pull the balancer off right? If I remember correctly....just the center bolt. Thanks
Old Jan 14, 2007 | 09:15 AM
AL SS590 M6's Avatar
Yes it does and to install it properly you should have a balancer installer tool.
Old Jan 14, 2007 | 01:58 PM
And you'll need a new bolt.
Old Jan 14, 2007 | 02:26 PM
myslowcamaro's Avatar
for the timing chain? which bolt? just curious, taking notes for when i do mine.
Old Jan 14, 2007 | 07:24 PM
The bolt for the balancer that you'll have to remove to get to the cover.
Old Jan 15, 2007 | 05:41 AM
Capn Pete's Avatar
Why would you need a new bolt for the balancer?? That's probably one of the biggest bolts on the entire car!! (it takes what, a 22mm socket I think, right?? ) ... why would you need a new one of those if you pull the balancer off??
Old Jan 15, 2007 | 10:31 AM
Supposedly it is torque to yeild.
Old Jan 15, 2007 | 06:31 PM
ok, i have new one only 3k miles old (came with h/c) should i replace it again then?
Old Jan 15, 2007 | 08:34 PM
If you torqued it, yes.
To swap the timing chaing you might as well get a cam change gasket kit and IIRC it comes with the gasket kit.
