Moser 12-bolt. Guys help me out here...
Old Feb 7, 2006 | 01:59 AM
zhevy-1's Avatar
Guys, I want to help a friend that I've sold a Moser 12-bolt off my 96 Z28 to.
Here's a little background, so you can understand the situation.
First of all, I purchased this 12-bolt off a 2002 Camaro SS less than a year ago. I gave seller my 10-bolt plus cash, he gave me his Moser 12-bolt. A local shop did the swap, and as far as I know, there was no issues with the swap.
Now let's forward to the present. I've just sold my Moser 12-bolt to a friend here in Colorado. He has a 2000 Trans-Am, LS1 of course.
He's now having problems with the install, and things are not clicking as it should with his install.
This is where you guys come in, and I want to ask you for answer to what's going on.
This is the post my friend posted on another board, see if you know what he's talking about...
Quote: "I bought a used Moser 12 bolt that was in a '96 Z28, this rear was originally in an '02 SS! (so things were changed)
it is correct 4 channel. ( I do have ABS/TC)
I found today the the brake brackets won't work, and the reluctor ring is different. 47 teeth on my stocker, 53 on the 12 bolt axles.
what do I need to make this work? is the inside diameter of my stock reluctor ring that same, so I can just re-use them on the 12 bolt?
and can I just call moser for the right parts to make it work with my stock brakes?
thanks for any help!"
Regards,
Goose
Old Feb 7, 2006 | 10:48 AM
zhevy-1's Avatar
Re: Moser 12-bolt. Guys help me out here...
If there's a place that know the answer, or can help my situation is here. Come on guys. Bring it!
Old Feb 7, 2006 | 02:38 PM
1SlowFormula's Avatar
I asume you had your stock brakes hooked to it? The backing plates are diffeent between the LT1 and LS1 years, and the shop probably swapped them out for you. I guess they didn't charge you if they did, or you would have known about it...
Never heard anything about the reluctor rings though so that is news to me. But I would think it should still work the same as long as they have the same count on both sides... But I could be wrong...
Old Feb 7, 2006 | 07:55 PM
zhevy-1's Avatar
Any other input?
Thanks!
TitoPR221
Jan 29, 2015 08:00 PM
ddr698
Jan 9, 2015 10:05 AM
Red97LT1
Aug 7, 2002 05:45 PM
