383 LT1. Want Boost. Change Cam?
Old Feb 6, 2006 | 04:44 PM
Will84's Avatar
History:
I have just completed a year long build-up/Install of my 1995 TA 383 LT1. Originally the plan was to have a strong N/A motor and add nitrous.
Specs:
  • 383, fully forged, fully ported,
  • Cam = 234/242, .568"/.549", 109 LSA
  • 11.5:1 compression.
  • more info at my cardomain page - link below
I'm hoping to make around 400-410 N/A
Questions:
  1. How much boost could this motor typically handle?
  2. Is is absolutely necessary to change the cam?
Thanks for any info.
Old Feb 6, 2006 | 06:10 PM
engineermike's Avatar
Re: 383 LT1. Want Boost. Change Cam?
Yikes! I'm usually pretty liberal when it comes to turbo cams and compression ratio's, but your's are both pretty wrong.
That cam MIGHT be okay, as long as you use a T-6 turbo and get the backpressure down to 1x or 1.5x boost. If you're stuck with a T-4 turbo like most of us, then you're going to have backpressure 2.5x boost, which will have pretty bad exhaust pollution of the intake charge.
As for the compression ratio, that's borderline naturally aspirated. Let alone boosted.
My answer: change the cam and compression, then install the turbo.
Old Feb 7, 2006 | 08:44 AM
Will84's Avatar
I figured that would be the answer. I'm just starting to learn about Forced Induction.
Thanks Mike.
Old Feb 8, 2006 | 01:13 PM
97WS6SCharged's Avatar
Stick with the nitrous and just buy 2 bottles instead of one.
Old Feb 8, 2006 | 03:10 PM
buzz12586's Avatar
x2
Old Feb 10, 2006 | 03:41 PM
Will84's Avatar
Yes... I better get 2
rideordie
Nov 5, 2019 04:52 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
nballisru
Dec 14, 2014 05:01 PM
Queens94z28
Nov 20, 2014 06:03 PM
