Thump under car on the 1-2 shift??
Old Feb 6, 2006 | 09:26 AM
2QUIK6's Avatar
On my '95 LT1 I can't seem to find anything loose under the car, and all the LCA and TA are tight. But when accellerating moderately, when the 1-2 shift happens, there a loud thump under the car about a split second afterwards.
It's almost like the drivetrain unloads at the top of 1st, then when it shifts to 2nd it loads up again, like shifting from Neutral to drive with the pedal down.
I have Spohn LCAs and the stock TA. I did have a Spohn TA that terminated at the tunnel brace, but thats when the thump began, it was so annoying that I removed the Spohn TA and went back with the stocker...now after several months, the thump has returned with the stocker torque arm on there. It does not thump if I accelerate lightly, and the harder I accelerate, the louder/harder the thump is.
I like a hammer hitting the bottom of the car.
Any ideas what I could look at next?
Thanks
Old Feb 6, 2006 | 09:31 AM
TraceZ's Avatar
Re: Thump under car on the 1-2 shift??
Transmission mount.
Replacing it is easy, just support the transmission with a jack and change it out.
Old Feb 6, 2006 | 09:32 AM
sabre81's Avatar
Check out the transmission mount, it is probably ripped/broken. You will probably have to remove it to find out whether or not it is broken. Visual inspection usually reveals nothing. Good time to replace with Poly mount.
Old Feb 6, 2006 | 09:58 AM
Blue89Bird's Avatar
another vote for tranny mount
Old Feb 6, 2006 | 10:17 AM
2QUIK6's Avatar
I guess that could be. When I had the Spohn TA on there I swapped out the LT1 mount for a new LS1 mount and that didn't fix it and the LS1 mount seems to allow the tranny to bounce around even more than the LT1 just by pushing/pulling by hand...so I put the LT1 back on when I put the stock TA back on there...
Guess I'll try a poly one now.
Old Feb 6, 2006 | 10:21 AM
Critter's Avatar
me 2
Old Feb 6, 2006 | 12:15 PM
Joe Bellman's Avatar
I agree. I have broke 3 of them on my car.
Old Feb 6, 2006 | 01:25 PM
TobyZ28's Avatar
About to replace my 2nd one now 99.9999% sure its your tranny mount. It'll happen more frequently going up hills and if you accellerate hard off the line.
Old Feb 6, 2006 | 08:31 PM
'86 350's Avatar
And for the hell of it..... I'll say tranny mount, same thing used to happen on a Fox body stang I test drove.
Old Feb 6, 2006 | 09:41 PM
2QUIK6's Avatar
Yep, it was the tranny mount, completely separated in two. I order a new poly one from Thunder Racing.
Thanks to all who replied!
Old Feb 7, 2006 | 11:15 AM
TobyZ28's Avatar
Just a side note, some people have said that poly ones on A4's cause some ugly vibes in the car... Seems to not be that big of an issue with M4's though
Old Feb 7, 2006 | 11:22 AM
sabre81's Avatar
Yep i can vouch for this. When my car was an A4, the poly mount rattled my teeth. When i did the a4 to m6 swap, the same poly mount was perfect.
Old Feb 7, 2006 | 06:03 PM
2QUIK6's Avatar
Yeah, I heard that as well and I've also heard folks say they didn't notice much difference. Guess it all depends on how much noise and grinding your drive train and rear end makes. Couldn't be any worst than the Torque Arm mounted to the tunnel brace noises.
Old Feb 8, 2006 | 12:43 PM
chris5388's Avatar
Yup tranny mount I broke mine and it did the same thing.
Old Feb 9, 2006 | 12:38 AM
TobyZ28's Avatar
Here is what my broken mount looks like, took it out today
