Hesitation
Old Feb 4, 2006 | 06:14 PM
SFB767's Avatar
Question Hesitation
For the past month, when I'm at a light or idling, my car kind of hesitates and feels like it wants to stall out one minute, and the next it'll idle like a Lexus.
The RPM and oil pressure needles both stutter somewhat, but once I take off and go on my way, everthing's fine.
Does anyone know what's wrong with my car?
Old Feb 5, 2006 | 03:31 AM
ryan1488's Avatar
Re: Hesitation
plugs, wires, coil pack for starters
Old Feb 5, 2006 | 11:21 AM
SFB767's Avatar
Re: Hesitation
I just put new plugs and wires in less than a year ago and I checked for any loose connections yesterday afternoon.
How would you determine if the coil pack is causing the problem?
Old Feb 5, 2006 | 06:17 PM
TransAmAbe's Avatar
Re: Hesitation
You'd have an SES light on and it would be likely, though not definitely, be a problem at throttle positions other than just idle.
Anthony, check your PM.
Abe
Old Feb 11, 2006 | 07:01 PM
ROL WTME's Avatar
Re: Hesitation
I would check the plug wires and coil packs as well. But if you say there were no loose connections, just start with the coil packs. If thats not the problem then check your fuel injectors to make sure none are clogged.
Heck, I would even check the current reading from the altenator, may sound silly but I would start cheap before I spent too much.
Old Feb 12, 2006 | 11:23 PM
380ss's Avatar
Re: Hesitation
Why not just take it in and have the dealership run it on the scanner. Just a thought.
Old Feb 13, 2006 | 03:05 AM
DaddySS's Avatar
Re: Hesitation
What is the voltage reading? When you say the tach and oil pressure stumble - do they drop a lot or just a little because the RPM is dropping?
Old Feb 13, 2006 | 01:42 PM
SFB767's Avatar
Re: Hesitation
Problem solved.
I overlooked the little rubber hose under the EGR plate. It had a hole in it, causing the leak. I replaced that hose and everything's fine.
94Z28LS1toLT1
Oct 4, 2015 11:28 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
