my car have posi?
Old Jan 27, 2006 | 12:07 PM
scott5's Avatar
my car have posi?
Did the 94 camaros come with posi?
Old Jan 27, 2006 | 12:15 PM
MyShibbyZ28's Avatar
Re: my car have posi?
All 4th gen LT1/LS1 camaros and firebirds came with posi-traction. If you want to double check it look for G80 on the RPO sticker. The sticker is in your glove box. G92 means you have the optioned gears, but that is only for automatics. GU2, and GU5 are for autos. GU6 is for a manual.
GU2: 2.73 gears
GU5: 3.23 gears
GU6: 3.42 gears
G92: performance option (3.23 gears for autos)
G80: posi
EDIT: If you want to triple check it do a burnout.
Old Jan 27, 2006 | 12:33 PM
rngilliland's Avatar
All V8 4th gen have posi. V6 cars as far as I know only had it as an option in some years up to 97. Don't know about the later model V6 cars. If your 94 is an LT1 it came with posi.
Old Jan 27, 2006 | 12:42 PM
scott5's Avatar
Yea its a 94 Z28 auto
Old Jan 27, 2006 | 01:14 PM
flatlander757's Avatar
Well in 94, if you have a "1" on the gear selector, you have 3.23s, if not, then you have 2.73s.
And yes it should have posi.
Old Jan 27, 2006 | 02:30 PM
RE AND CHERYL's Avatar
Just because GM built it with a posi, dosn't mean it's still doing it's job. The one in my 94 was wasted at 115k. The new rear I installed with an Aburn has made the car a blast to drive agian.
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
USAirman93
Nov 24, 2014 03:37 PM
IgorT.455/406
Feb 1, 2005 06:18 AM
IgorT.455/406
Jun 4, 2003 03:32 AM
wytblur
Mar 2, 2003 03:40 PM
