Crank Trigger -vs- Dual Sync Distributor
Old Jan 22, 2006 | 09:39 PM
Sean94Z's Avatar
I am pretty sure my opti has gone bad again. I am running GEN7 DFI, so, adding a dual-sync distributor would be an option. Now the question is, take the intake off, drill it for a distributor and run a dual-sync, or replace the opti and add a crank trigger for the crank signal so I can run sequential ???
Any opinions?
Thanks,
--Sean
Old Jan 23, 2006 | 06:12 AM
Maldo's Avatar
Re: Crank Trigger -vs- Dual Sync Distributor
Any opinions?
Thanks,
--Sean
where are in toms river ... I used to cruise that area all the time with my green 97 camaro (with a blower ) i used to hang out with a guy name John (he had a 98 red z/28) lol
are you by seaside
Old Jan 23, 2006 | 07:16 AM
Sean94Z's Avatar
Toms River isn't that big .. I know John, haven't seen him in a while, I don't cruise 37 too often anymore .. Too much at stake w/ all the cops and ricers ..
Anybody else have any opinions on the above matter?
Old Jan 23, 2006 | 08:57 AM
Birdie2000's Avatar
Does the dual-sync allow you to run sequential as well?
Old Jan 23, 2006 | 09:10 AM
Sean94Z's Avatar
Yep, the dual sync gives the crank and cam signal so I can run sequential. But, I've heard of people running a flying magnent or crank trigger in high horse-power applications instead of the dual-sync because the signal gets skewed or something with the dual-sync..
Old Jan 23, 2006 | 09:15 AM
Birdie2000's Avatar
That's what I thought. Yeah, I've heard the same thing before. Does it seem to be a widespread issue with the dual-sync or just a few people saying this? I'd think if it was a big issue it would be fixed, but who knows.
Old Jan 23, 2006 | 11:26 AM
Maldo's Avatar
don't mean to hijack this thread .... yes have not been there in years .... 37 was fun back in the day
Old Jan 26, 2006 | 04:22 PM
LS1-TeK's Avatar
Nobody has answered the guy's question yet. lol. I would if i had an answer but please people. Get to the point here.
Old Jan 26, 2006 | 07:53 PM
Birdie2000's Avatar
I'd lean towards the crank trigger setup since the dual-syncs seem to have problems. The only problem is the machining required for a blower setup cause of the pulley. Granted the intake would need to be drilled for the distributor, but I'd just go to a single plane myself if I were doing that.
jwade88
Jun 14, 2015 09:38 PM
dplatt3
V6 Tech
Apr 30, 2015 10:44 AM
TT350
Mar 31, 2015 07:44 PM
greenzee28
Mar 26, 2015 09:13 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
