hesitation and misfire on 94 3.4L
Old Jan 22, 2006 | 08:59 PM
bowtiethunder's Avatar
my gf has a 94 3.4L camaro. It has a hesitation and takes spells where it misfires badly at idling and cruising. I have changed spark plugs, wires, air filter, and pcv valve. I have also cleaned the throttle body and the IAC valve. Is it the coil packs?
Also is the fuel filter the same as a LT1 cause I got a good one laying around?
Old Jan 23, 2006 | 12:57 PM
valter's Avatar
Re: hesitation and misfire on 94 3.4L
I had a pretty bad misfire due to faulty coilpack. There also a chance, that seals under coilpacks are bad and moisture are getting there (I think it's the same design as on 3.8L).
Jeff1904
Jun 5, 2016 05:00 PM
93 RedBird
Nov 15, 2015 08:24 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
greenzee28
Sep 25, 2015 04:29 PM
MDZ28
11
Sep 24, 2015 09:15 AM
