MAF Location = Problems?
Old Jan 20, 2006 | 10:05 AM
Kbird's Avatar
I believe I know the answer, but looking for comfirmation or thoughts.
The story - I have a 69 camaro with an LT4 / T56 set-up. I'm in the process of determining where to locate an air filter and routing to the TB. I have considered using a stock type camaro TB elbow and pull air from the fender well similar to other CAI's. I can't route to the drive side and passenger side area is pretty conjested. I have thought of coming up with a way to pull air from my cowl induction hood. My concern is the MAF location. Are there rules of thumb that I should be aware of to ensure I won't have MAF or drivabilty issues?
Thanks,
Kevin
69 camaro LT4 / T56 9" Mini tubbed 315/17 245/17 Budnik Hammer DSE suspension 6pt. cage Baer brakes Vintage Air......
Old Jan 25, 2006 | 05:56 AM
Kbird's Avatar
Re: MAF Location = Problems?
No response?
Does changing the MAF from the stock location cause problems? Do people not move it or if they have to they go to Speed Density?
Thanks,
Kevin
Old Jan 25, 2006 | 07:43 AM
shoebox's Avatar
As long as the MAF is in the air flow from filter to throttle body, there should not be any problem.
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
pete53
Dec 9, 2014 07:31 AM
formula218
Dec 2, 2014 04:27 PM
siguy
Nov 27, 2014 10:07 AM
94B&RZ-28
Dec 22, 2008 10:00 AM
