what do i need?
Old Jan 2, 2006 | 07:11 PM
fstenuf's Avatar
what do i need?
hey- i thought about puttin n2o on my car but i was wondering what all i need in order to do so? All i want to run is a 100 shot(maybe less). do i need a window switch? bottle warmer? let me know what you guys think.
Thanks!
Andrew
Old Jan 2, 2006 | 07:20 PM
Nitro Dave's Avatar
Re: what do i need?
Andrew I always suggest a window switch for safety.This is the most needed saftey device you can add. A system can work with out a bottle heater. However if the pressure is down the system will not make the hp it is suppose to.You may also not be able to use as much of the nitrous in the bottle.
Dave
Old Jan 5, 2006 | 09:20 PM
fstenuf's Avatar
Re: what do i need?
Is there a certain part number i need? brand recomendation?
Old Jan 5, 2006 | 10:58 PM
Nitro Dave's Avatar
Re: what do i need?
We offer a lrage amount of different brands. Do you know if you are leaning towards wet or dry? any certain system have your eye as far as stsyle? The most common system on the market is the NX single nozzle system.
Dave
Old Jan 6, 2006 | 07:32 AM
HarrisSpeedWorks's Avatar
Re: what do i need?
Hi Andrew,
The window switch is a real good idea. You might also want a fuel pressure safety switch. I'd also suggest a set of colder spark plugs, like a set of NGK TR-6s.
Matt
Old Jan 7, 2006 | 08:29 PM
fstenuf's Avatar
Re: what do i need?
i heard that a wet system is better, is that true? i was leaning toward the NX system but idk a part number or anything that i need extra to make it a complete kit.
