Switching dash boards LT1 to LS1
Old Dec 24, 2005 | 02:32 PM
wb3s94z28's Avatar
Has anyone done or does anyone know if you can swtich out the stock dashes (the whole dashes). I want to put one like a 98 in my 94, is it possible?
Old Dec 25, 2005 | 08:00 PM
96m6lt1's Avatar
Re: Switching dash boards LT1 to LS1
i would say yes,since the 97dash in the lt1 is the same dash as in the ls1
Old Dec 25, 2005 | 08:09 PM
Honda Hunter's Avatar
enter dash swap or digi odo in search and youll get some good info.
Old Dec 25, 2005 | 11:22 PM
merim123's Avatar
I'm going to be doing this in a few weeks, I have most of the parts now. There are several decisions you need to make. Most people will say this was discussed several times on this board and it's probably in several different postings, however there are some key things I would say after going through the hassle of getting all the parts, my opinion ofcourse, YMMV>>
1) make a decision on firebird/trans-am dash or camaro dash.
2) Make a decision on the color ( I went with ebony and that limits your options to 00-02 cars and also higher prices)
3) How much are you going to replace? just the dash or entire interior? I went with entire interior so more cash
4) all the small parts like bezels, vents, power switches, etc. I went with trans am door panels and camaro dash for my camaro, so I had to get all the parts extra
5) 97 speedometer. I got one to work with my 96 wiring harness, I think I'm ok, but will soon figure out.
There's probably more but I don't know until I get into it further.
Old Dec 26, 2005 | 02:47 AM
Very good post. Im in the process of doing it now. Biggest issue for me is getting the parts. How hard was it to get the 97 digi odo to work?
Old Dec 26, 2005 | 10:21 AM
merim123's Avatar
don't know yet, haven't tried. I'll post it up, once I try.
Old Dec 26, 2005 | 10:46 AM
90 Z28SS's Avatar
All you need to do is make sure you have the cluster wired up right . Since you have a 94 Camaro , I would use a wiring skematic from a 94 trans am cluster connector . If you had a 96 Camaro , I would just use the obd2 97 wiring skematic . In my 95 trans am , I used a 97 cluster . I had to do nothing . The pinouts in the cluster connector were the same for the 95 style and 97 style odo's . Both the 93-96 analog and the 97 digi odo's got the same signal from the pcm
Old Dec 26, 2005 | 11:13 AM
Where can I get my hands on the wiring schematics for 94, 97, and 97 firebird?
Old Dec 26, 2005 | 11:26 AM
90 Z28SS's Avatar
Go to your local public library . They should have all the dealer service manuals , the GOOD books the service techs use . Its all I use when I need any type of automotive wiring info . Every circuit in the car is in there .
Old Dec 26, 2005 | 03:10 PM
96m6lt1's Avatar
i was told when i was going to do a similar swap the 97 cluster will swap into the 96 and work properly,still not absolutely sure but will do it as soon as i get a 97-02 cluster
Old Dec 26, 2005 | 06:41 PM
merim123's Avatar
I heard the same. When the cars went OBD2 in 96, the same wiring harness stayed through 02, but I haven't taken the dash off to confirm. I don't know if anyone with a 96 has tried the swap yet. Most of the posts I've come across are 94/95 cars.
Injuneer
Dec 15, 2014 09:36 AM
ChrisFrez
Nov 23, 2014 10:33 AM
Rich_z28
Aug 29, 2002 10:44 PM
