car alarm in 96Z, unlock mod
Old Dec 23, 2005 | 09:21 PM
Hawk's Avatar
Putting in the alarm in this thing, after the RAP turns off the power to the BCM the alarm won't unlock the doors.
I looked at brents page with the diode trick and tricking the BCM to wake up, but that wasn't 100% what I wanted because if i turn off the car my alarm automatically unlocks the door and I lose the RAP feature(BCM will sense door open then close).
I just started to wire it up with a little mod to brent's guide, instead of wiring the wakeup negative trigger signal directly from the alarm to the BCM door input, I put a relay in there that only lets it do that when the RAP is deativated. Meaning, when RAP is on the alarm will not send a negative pulse to the BCM, and when the RAP is not on it will send the negative pulse to the BCM so that it wakes it up. This should let the alarm work as intended, with automatic unlock and no RAP deactivation.
Anyone ever do it this way?? In theory it should work 100%.........
Old Dec 24, 2005 | 09:52 PM
Javelin3o4's Avatar
Re: car alarm in 96Z, unlock mod
The tan will unlock the drivers door and the gray/black will unlock the passenger door. Wire each as a 5-wire system with separate relays. See direct fax document #1052.
Noenav
Mar 1, 2019 07:38 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Queens94z28
Nov 20, 2014 06:03 PM
dreamer1q
Jul 24, 2002 04:39 PM
