Solid roller lifters/hyd cam?
Old Dec 22, 2005 | 07:27 PM
blown69nova's Avatar
I talked to the tech guy at Comp and he says you can, but has anyone tried this?
I'm using the extreme energy 224/236 .573/.593 116 lsa hydraulic roller and I'm contemplating using solid lifters to gain valvetrain stability at higher rpm's, what do you guys think?
Thanks, steve
Old Dec 22, 2005 | 08:07 PM
Black Cloud's Avatar
Re: Solid roller lifters/hyd cam?
Thanks, steve
He said you can use the hyd. roller cam with solid roller lifters?That's the first time I've heard that but if their roller cams are both billet I don't know why you couldn't.
Let me know.You might want to call another cam manufacturer and see what they have to say.
I'm very interested.
John
Old Dec 22, 2005 | 09:29 PM
That is what he said and I didn't even think to ask if the cam core was billet. He said I would have to run a tight lash of .006-.008.
Steve
Old Dec 22, 2005 | 10:43 PM
flyinZ's Avatar
A buddy of mine and I were just talking about that.He said that turbo buick guys, have been doin' it for years...Set valve lash one time,more efficient at higher rpm,etc...(i think) Hopefully he'll chime in on this.
Old Dec 23, 2005 | 12:32 AM
atljar's Avatar
Kinda pointless to sacrifice everything a hydrolic offers for all the downsides of a solid without even gaining the HP gains possible with a SR cam????
Old Dec 23, 2005 | 09:41 AM
SStrokerAce's Avatar
You can do it you just need to know the lash specs for the lobes you are running.
Bret
Old Dec 23, 2005 | 12:43 PM
Big454blockchevy's Avatar
With it not being a billet core won't it damage the lobe?
Old Dec 23, 2005 | 02:45 PM
If the spring loads are too high it definately could wipe one out.
Most likely it's not going to with the hardness of the lobes. If there is enough case you will be fine, and the spring pressure required on the cam will only be a little bit higher.
Bret
Old Dec 23, 2005 | 03:37 PM
I know nothing but positives on running a solid roller.
If you run polylocks you don't have to set them that often unless you're turning 9000rpm or more.Since you set the lash you know what you have and it should run more consistent.
Hydraulics can start leaking down and I noticed on my LT1 I had a diffenent problem.I've been adjusting them with the engine running.That's the only true way to get them right.But it can get messy.
My new engine is a pretty good size smb and I look at the solid rollers every day.
Old Dec 23, 2005 | 04:42 PM
walt355's Avatar
Ive always heard that the ramp on a hydrolic cam lobe was diffrent than a solid lift cam lobe?
Old Dec 23, 2005 | 07:53 PM
atljar's Avatar
Well my downsides would be having to check and adjust lash, noise, and possibility of needle bearings shooting all over you engine. Not to mention cost.
While you can set your lash to .0XX, and technically should be more accurate, thats only going to be as accurate as the person setting it. You dont have near the leeway (sp?) that you do with a hydro.
Im not an engine builder, but i just cant see major gains, or the minimal gains being worth it. (at least speaking of hydro cam with solid lifters). A solid roller designed lobe + solid lifters you start to make up for drawbacks in power.
Old Dec 23, 2005 | 07:55 PM
atljar's Avatar
For the most part a solid roller has much steeper ramps than a hydrolic cam. This is how you can have two cams with the same advertised duration, yet the solid may have much more .050 duration. Solids get the valve open quickly, hold and slams shut, where a hydrolic is more of gradual rise and fall.
Old Dec 23, 2005 | 07:56 PM
MEAN LT1's Avatar
So is it true that when running a SR the lash should never change. If it does its a sign that something in the valvetrain is wearing or about to go?
Old Dec 24, 2005 | 11:38 AM
1racerdude's Avatar
Generally that's true. They will have to be set every so often.
If ya set them after the first 500 miles and they don't go 5000 miles before setting needs to be done then something is going away. The first few miles seats everything in then ya should be good to go for a while.
The reason ya see it all the time at the track is to make sure nothing is damaged and get ready for the next pass.
Old Dec 24, 2005 | 04:19 PM
Problem is the advertised duration on a solid is not rated at the same lift. A Hyd Roller is rated at .006 and a SR is usually in the .014-.020 range.
FWIW they are both roller profiles they do a lot of the same things the same way.
Bret
