MTX Amplifier - No Sound
Old Dec 21, 2005 | 12:52 PM
EviLBoX's Avatar
I have a 6 yr old MTX 2150 amplifier driving my 2 front component speakers. On a recent car trip I noticed the front 2 speakers making a loud popping sound when I would hit a bump. It turned out to be something in the back of my car hitting the RCA connection on the amp causing the popping. I know this because when I wiggled the RCA connection I could hear the popping. Well being the intelligent person I am, I kept fiddling with it until finally the speakers stopped working. The amp still has power, but I get no sound to the speakers. I swapped the amp out for a different one and that works, so it must be the amp. None of the fuses are blown, I even opened the amp and all the caps look fine. Any idea what I might have screwed up? Thanks.
Old Dec 21, 2005 | 02:15 PM
LS1 RULZ's Avatar
Re: MTX Amplifier - No Sound
Chances are the solder joints that hold the RCA connections to the circuit board have cracked. You may be able to fix it by re-flowing the solder joints. If the traces on the circuit board have cracked the repair will be a little trickier.
Old Dec 22, 2005 | 07:07 PM
Critter's Avatar
you sure those rca jacks where working fine. jiggle them with the new amp and see if they cut in and out. if it works through all that go with what ls1 said. pray its the rca's
Old Dec 23, 2005 | 09:07 AM
EviLBoX's Avatar
I took a look at the RCA connections to circuit board and they're fine. I'm going to plug the amp in one more time and give it a try, if it still doesn't work I think the amp is toast. Thanks guys.
Old Dec 23, 2005 | 10:09 AM
Critter's Avatar
mtx repairs amps for 90 bucks
Old Dec 23, 2005 | 02:20 PM
EviLBoX's Avatar
Well after opening the amp, I went ahead and hooked it back up one last time. Surprisingly it worked, although now when I start my car it picks up a lot of engine noise, there's a very loud whine. Of course when the car is off it doesn't do it.
Old Dec 23, 2005 | 06:52 PM
EviLBoX's Avatar
I figured out the problem, the ground connection on the RCA jack was messed up. I tried resoldering the connection, but that didn't help. I ended up directly connecting the ground part of the RCA jack with a wire to the ground on the circuit board. Not the most advanced solution, but it works.
94Maroz28
Oct 27, 2015 04:38 PM
PopoFormula
Oct 12, 2015 04:19 PM
4586
Sep 27, 2015 01:55 PM
autoxr166
Sep 25, 2015 04:21 PM
Ryan Ramsaran
Sep 19, 2015 08:43 PM
