Window Problems.
Old Dec 10, 2005 | 05:02 PM
1FstFormulaV8's Avatar
Window Problems.
Once again my power motor is out! Yes. Now it's just buzzing to and making the door vibrate. Not going anywhere but down. The window is holding right now. It's about 2" down. Its' like the motor is still operating but not making full contact with that gigantic gear in the regulator. I can pull the window to the top with manually but it just drops back down again.
And there's one more problem. It seems the mount holes on the door are ripped down the door about .5". I know this can't be good. Any ideas on how to approach this? I need all the help I can get!
Old Dec 12, 2005 | 05:35 AM
Guest47904's Avatar
Guest
Re: Window Problems.
More than likely, the regulator dropping down is what caused the problem in the first place. Try to move it back up into place and mark the location. Then drill out the rivets and check all the tracks and rollers while you have it out. Patch the worn out holes with something like Nitrostan or Bondo and drill them out in the place you marked them. A replacement regulator will not come with hardware.
Old Jan 5, 2006 | 06:22 PM
co93z28's Avatar
Anyone know how to get the window regulator back in the door and hooked up ?
Help !!!!
Old Jan 5, 2006 | 08:40 PM
co93z28's Avatar
Well I got it back in and worken, but don't ask me how I did it and I would never attempt it again, NOT FUN !!!!! Thanks for all your help.
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
z28cam1993
Sep 9, 2015 04:08 AM
realistyc
Jul 28, 2015 07:32 PM
