If bore and stroke is unknown?
Old Dec 9, 2005 | 02:25 PM
CheshireCat's Avatar
Can I figure out what the compression ratio of a 400 cid motor is using a compression gauge? Is there a direct relationship between PSI and CR?
Thanks,
Steve
Old Dec 9, 2005 | 02:32 PM
Re: If bore and stroke is unknown?
I'm not sure I get what you're saying...
Are you saying that due to pressure loss around piston rings, the gauge might be inaccurate?
Old Dec 9, 2005 | 02:59 PM
I figured that the PSI reading wouldn't account for pressure lost due to cam duration...
Basically, I've come into posession of a 67 Camaro with a 400 cid motor that was clearly built to be a 1/4 mile car... (Roll bar, fuel cell, stripped bare for weight reduction, M/T drag slicks) but I don't have any specs on the engine internals... I have started it up and it will idle (VERY CHOPPY) on 93 octane, but I don't know if the motor was built for race gas only... This thing is in no way street legal....
Short of driving it hard and listening for knock... How can I figure out what fuel I should be running?
Old Dec 10, 2005 | 10:29 PM
kevin426hemi's Avatar
the only way to know for sure is by removing the cyl. head and mesuring the cc's of the combustion chamber and piston area at tdc. - of if you know the part # of the piston.
best bet run 50/50 racing fuel and prem.
good luck
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
Z Power
Sep 19, 2015 11:19 PM
heus
Sep 8, 2015 12:01 PM
POLOVETTE 94
Aug 21, 2015 07:11 PM
