Coolant/Leak-Adding "the stuff"
Old Nov 29, 2005 | 06:48 PM
93 LT1's Avatar
Guys I need some help! There are two type of cooling systems used on the LS1. The LS1 F-body has the has removalble radiator cap..makes adding and checking easy. The LS1 in the Y-body has a sealed radiator and a "pressure tank".
I got a small leak that I want to make a quick repair-by adding the stop leak stuff. Just need to get me buy for a short time. (ususally don't add this stuff)
My question IS how can you add this stop leak to a cooling system similar to the one in a Y-body? Throwing it into the pressure/overflow tank will do nothing!
Any help would be greatly appreciated!
Old Nov 29, 2005 | 07:33 PM
Greed4Speed's Avatar
Re: Coolant/Leak-Adding "the stuff"
The 01 Grand Am has a pressure tank system. I put stop leak in the pressure tank of ours and it worked. Ran that stuff for over 3 years of high milage driving. The car now has just shy of 150k miles and stays cool. Only thing I had to do to the cooling system was replace the t-stat around 130k miles. Thats besides normal maintenance. I won't run Dexcool 5 yrs 150k miles just like I won't run platinum plugs 100k miles. I've even ran a mix of Dexcool and conventional antifreeze for most of it's life.
Old Nov 29, 2005 | 08:03 PM
93 LT1's Avatar
Thumbs down Re: Coolant/Leak-Adding "the stuff"
Ok, so you just poured it all in there when the engine was running and then just drove it?
I don't see what the advantage is of this system. Just put a cap on the radiator!
Old Nov 29, 2005 | 08:47 PM
DaddySS's Avatar
Normally those caps come off with a pair of channl locks, haven't seen the one on the Y body so I say "normally. If you're concerned you could also pull the upper radiator hose off, let a little fluid out and pour it in there?
Old Nov 29, 2005 | 08:54 PM
The advantage is with more pressure the boiling point rises.
I poured it in then it got driven for 78 miles on the way to work.
Its nice not to live in BFE anymore.
Old Nov 29, 2005 | 10:04 PM
93 LT1's Avatar
Thanks guys!
DaddySS: That is EXACTLY what I did and it worked perfectly.
