Ltx + Sts
Old Nov 29, 2005 | 06:38 PM
NuMbNuTs670's Avatar
Ltx + Sts
I recently had a valve train failure( bottom end is damaged and valves bent) and was thinking about buying a low milage LT engine and dropping it in while i rebuild the motor during the next couple of years. Did all the LT corvette engines have 4 bolt mains and would the motor with a upgraded fueling system and tune hold 5-8PSI good?
Old Nov 30, 2005 | 08:00 AM
Re: Ltx + Sts
ttt
Old Nov 30, 2005 | 09:28 AM
teke184's Avatar
Re: Ltx + Sts
why not just get an ls1 crate motor?
stronger, more power from the start, and more potential.
Old Nov 30, 2005 | 03:47 PM
5.0THIS's Avatar
Re: Ltx + Sts
Old Dec 1, 2005 | 10:30 AM
Kredz28's Avatar
Re: Ltx + Sts
LS1's are great engines and in bolt on form will obviosly make more hp than a bolt on lt1. Its also a more expensive engine. Once you build a boosted motor with a forged bottom end, ported heads, cam, etc...the benefit of an ls1 is tiny at best. Since hes wanting to run boost and in case hes on a budget, an ls1 might not be practical. Plus, iron block > Aluminum block in boosted applications.
Henson071
Sep 18, 2015 04:01 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
speedracer1280
Sep 8, 2015 06:12 AM
Henson071
Aug 4, 2015 09:32 AM
disasm
Nov 26, 2003 06:56 PM
