Tunnel brace
Old Nov 12, 2005 | 03:38 PM
TJ Chapman's Avatar
Tunnel brace
I just installed pacesetter LTs and their off-road y-pipe. But now my tunnel brace won't go back on. I took it off so I could maneuver the pipes better, but now the y-pipe wont fit through it. I believe its the tunnel brace, its the brace right behind the tranny that the exhaust and driveshaft run through. Did anyone else come across this problem? Can I just buy an aftermarket tunnel brace? If so, where can I find one?
Old Nov 12, 2005 | 03:44 PM
Birdman7389's Avatar
Re: Tunnel brace
Common problem. You can get some washers and longer bolts, or just do like I did and leave it off....
Old Nov 12, 2005 | 06:49 PM
97LT1F-Body's Avatar
Re: Tunnel brace
I had the same problem but I left the original off and bought a aftermarket one. Its a BMR driveshaft safety loop and I added a couple extra washers to make sure there was no rubbing.
Mike
Old Nov 13, 2005 | 08:49 AM
2000GTP's Avatar
Re: Tunnel brace
I had the same problem, you could leave it off, use the longers washers/bolts idea, or you can buy an aftermarket tunnel brace from Spohn or BMR, but they will run almost 100.00 I left mine off and I didn't notice any adverse drivability.
Old Nov 13, 2005 | 04:53 PM
TJ Chapman's Avatar
Re: Tunnel brace
I might as well buy a spohn or a bmr driveshaft loop, cuz they're required once you break into the 12s at the track anyway, so 89 bucks ain't that bad
CARiD
Sep 30, 2015 05:44 AM
Slayer
Aug 17, 2015 03:55 PM
realistyc
Jul 28, 2015 07:32 PM
mrwz28
Jul 8, 2015 09:11 PM
Noer
Parts Wanted
Jul 4, 2015 05:13 PM
