STB....3 or 2 point?
Old Oct 27, 2002 | 08:46 PM
kandied91z's Avatar
Question STB....3 or 2 point?
and why?
Old Oct 28, 2002 | 07:44 AM
87DJP2001's Avatar
Any STB is a improvement, I have the two point Hotchkis one and it works fine. My opinion on the three point ones is that it just ties into the thin sheet metal of the firewall and doesn't do much except clutter the engine compartment. You may have to remove
it to do any servicing.
Old Oct 28, 2002 | 08:09 AM
Jim85IROC's Avatar
The only advantage that I see to a 3 point brace is that it may be stronger than a 2 point. I don't really see where the car flexes much in a front-to-back motion, plus the sheetmetal is thin like 87DJP2001 said. But... if it makes the bar stronger, then I suppose it will do a better job of keeping the strut towers from moving.
I'm using the 2 point Jamex bar and I was impressed at the difference I could feel. The car steers noticably better and is MUCH more quiet over bumps. I bought the Jamex because it was too cheap not to ($30 shipped ), and with the polished finish, it matched my engine bay nicely.
Old Oct 29, 2002 | 09:59 AM
Ucantcme57's Avatar
From a structural standpoint the brace will be stronger using a Triangle which everyone knows is the strongest shape. The triangle helps stop deflection of the bar and resists bending.. I would go for the three, I mean how hard is it to take it off? Not to bad, that I would think.. I have even seen some with swing out clevis's to help so you only have to unbolt one of them..
Old Oct 29, 2002 | 04:57 PM
Irocvette355's Avatar
I have the Edelbrock 3-point. Like everyone says, the triangle is the strongest shape, so I guess I have a strong STB.
Old Oct 29, 2002 | 08:50 PM
lonsal's Avatar
How about a 4-point? I modified my Edelbrock 3-point to tie into the radiator support. Since my car is a convertible I figured it would benefit from the extra chassis support.
Lon
Old Oct 30, 2002 | 05:30 PM
LT1Powered85Z's Avatar
3 point is worthless...it's just another gimeck. Kind of like saying you sell different stages of porting for cylinder heads. Lame.
The shock towers aren't pushed fore or aft so why would you need anything going from front to back or vice-versa? The shock towers are only pushed up when in a corner and having a brace that keeps them the same distance apart keeps them from flexing and allows the car to handle better.
The best kind of brace to get is one that is adjustable. Therefore you can preload the towers to keep them planted firmer on the ground. It only makes sense.
So many companies sell stuff purely for asthetics. How sad.
Although that 4 point one looks kinda neat, I wouldn't want anything to do with it. What a pain to do ANYTHING under the hood.
Eric
Old Oct 30, 2002 | 08:37 PM
lonsal's Avatar
Most maintenence items can be done with the 4-point STB in place. But removing it is a 5-minute job (6 fasteners). I've had it off at least half a dozen times.
Lon
Old Oct 30, 2002 | 08:45 PM
87DJP2001's Avatar
Everyone has his own opinion on a 2 or 3 and in some cases a 4 point STB. I have a 2 point Hotchkis one and it does the job. So pick the one you like and don't ask opinions because there is no set answer.
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
