roll cage instalation
Old Oct 31, 2005 | 10:08 PM
dragster98's Avatar
i was looking around for a shop to do my 10 point cage found this guy who seems to do great work below is the price he quoted me do you think that is a little high
" Generically speaking there are 22 weld joints (tig
welded) plus prep work and welding the plates to the
floor (mig welded) after cleaning. approximate cost
$1,200.00 to $1,400.00 for installation. As for the
tubs it depends how clean the car is and the prep work
involved and the way you want them done. Making the
original units wider or replacing them all together
affects the cost."
let me know what you think thanks
Old Nov 1, 2005 | 07:26 AM
dragster98's Avatar
Re: roll cage instalation
anyone?
Old Nov 1, 2005 | 08:01 AM
tonylittell's Avatar
Bout Right
Old Nov 1, 2005 | 03:12 PM
MyShibbyZ28's Avatar
1,200 to 1,400 for welding? I would never pay that much for something like welding. Yes i know there is a lot more involved then just welding but still. I'd buy my own and do it myself.
Old Nov 1, 2005 | 03:23 PM
ind when your car isnt scaled and tied together right and you launch into the wall you'll wish you had.....putting a cage in a car is alot more involved then just welding plates and tubes in a few spots.....atleast if you want it done right it is
Old Nov 1, 2005 | 03:41 PM
The welding is critical on a full cage. NHRA will not accept it for sub-10 second certification if the welds aren't done correctly, or if the welds have been ground down. Having a welder who knows the NHRA (or IHRA) requirements, and can meet them will save you a lot of grief in the long run.
Old Nov 1, 2005 | 06:22 PM
dragster98's Avatar
yea im going to have skeeter do my car i want it done rite the first time ill post pics as i get them
check out his work http://www.skeeters-law.com/Performance.html
Old Nov 1, 2005 | 07:27 PM
Well I do not plan on getting in to the ten second line just yet. I'd like a 4 or 6 point roll cage, that's all. Enough to stiffen the cassis but nothing to stop the car from rolling over. Hell, a bolt on roll cage would be good enough for me. (since my car is completely stock)
Old Nov 1, 2005 | 11:22 PM
Boosted_Z28's Avatar
If you are looking to "stiffen" your chassis, you might want to look into a set of sub-frame connectors first before you decide on installing a roll cage/bar. Sub-frame connectors will generally help with flexing of the chassis and will cost a lot less to purchase and install. I doubt that you would see much benefit from installing a rollcage in a stock vehicle, not to mention that access into and out of the vehicle becomes more difficult and your back seat is all but useless.
Old Nov 2, 2005 | 08:48 AM
I "combined" my roll bar with SFC's...... The front and rear connections for the hoop and braces are into the subframes, and the points where they connect to the subframes are in turn connected with custom SFC's, all chrome moly. Its a fully custom setup, and it wasn't cheap. But it fits in the car exactly the way I wanted it, saves about 35# with the chrome moly, and ties the front and rear subs together solidly.
You also need to keep in mind that a bar becomes quite unfriendly on the street, providing new places for your head to impact in a crash. The required "padding" is designed to protect a helmetted head, not a bare one.
http://cjcfo.fbody.com/members/injun.../DCP03794a.jpg
Old Nov 2, 2005 | 07:33 PM
dragster98's Avatar
i understand what your saying but the car will be far from stock i plan to build it primarly for the strip and ocasional street use if i break into the tens great then im all set i belive my bars will go over the back seat but i dont plan on using them any ways
Old Nov 2, 2005 | 07:37 PM
dragster98's Avatar
Talking Re: roll cage instalation
i hear ya on that on ill be sure to keep straped in via 5 point harness
Nov 18, 2023 07:21 PM
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
Doug Harden
29
Jul 30, 2003 07:05 AM
