Help, ABS unit wont send fluid to rear breaks
Old Oct 30, 2005 | 12:23 PM
93transam1234's Avatar
i pulled off moduel on top of the abs unit for the rear and it had presure, but none going into the line. i dont known what to do.
fyi. the brake light is on
Old Oct 30, 2005 | 12:31 PM
grandnational007's Avatar
Re: Help, ABS unit wont send fluid to rear breaks
i remember reading something about the car cant be jacked up to get fluid to the rears, something to prevent fluid leaks while on a lift or something. I think you have to use a special tool to bleed fluid to the rears if its on a lift, or you have to jack up the rear end itself to bypass the fluid restrictor. not sure though. someone please chime in
Old Oct 30, 2005 | 08:10 PM
i leveled the car and hooked up the traction control unit to the rear and unhooked the batery for 10 min, then it started working....
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
ddr698
Jan 9, 2015 10:05 AM
Rod Bender
Jan 1, 2015 03:18 PM
slothgrant
Aug 22, 2002 03:01 PM
