what different ways are there to get trans fluid back in my 6spd?
Old Oct 27, 2005 | 07:48 PM
Donohue96M6Z28's Avatar
how do you get the trans fluid to get back in the trans??? its not like i can poor it or anything, let me know ifyou can help
thanks
Old Oct 27, 2005 | 07:53 PM
FuryZ28's Avatar
Re: what different ways are there to get trans fluid back in my 6spd?
Go buy a siphon pump. Not only can you pump new fluid in with it, but you can also suck the old fluid out as well...
Janny's Avatar
There's a fill plug on the side. Unscrew it and pump the oil in. A pump wouldn't cost much more than 10$ I'm sure. Or take the shifter off and dump a gallon in there. Done.
Old Oct 27, 2005 | 07:59 PM
SantaCruz163's Avatar
Remove your shifter and and the fill plug. Start filling the fluid from the shifter area and once it spills out of the fill plug your done. A lot easy that way.
Old Oct 27, 2005 | 08:01 PM
well im having problems even checking it. i cant get under my car(dont have any toolsd where im living), anyway to get around checking it from underneath? if i was low would i notice trans problems, or would it just start tearing stuf fup?
Old Oct 27, 2005 | 08:21 PM
also is there anyway to fill from the shifter without taking out the filll plug
Old Oct 30, 2005 | 03:48 PM
StrokinIt383's Avatar
Yes but you dont want to overfill it. That is the purpose of removing the fill plug. You just fill it until it starts to come out of the fill hole. Make sure youre on flat ground though. You dont want to overfill or underfill. Its so simple and not to mention easy to get to i dont see why there would be a problem removing it. Its on the drivers side and all you need is a 3/8" extension. Hope this helps.
PCLZ28
Dec 24, 2015 05:19 PM
jb4xx
Feb 2, 2015 10:00 PM
David Dorris
Jan 17, 2015 08:10 PM
ro2207
Dec 4, 2014 06:18 PM
TYLER94Z28
Dec 3, 2014 07:05 AM
