Cheap rear end
Old Oct 25, 2005 | 04:16 PM
Grims's Avatar
Cheap rear end
I'm to cheap to put down a couple grand on a strong rear end so I can run some ET streets, Is there anything I could get from a junk yard that will bolt in that is stronger than what i got now?
Old Oct 25, 2005 | 04:59 PM
Z95m6's Avatar
Re: Cheap rear end
The cheapest thing you could do would be buy a Moser Bolt in housing, torque arm and 31spline axle setup. This runs about $950. Then you'll have to go to your local salvage yard and search junk cars/pickup trucks for a 31 spline, posi 9 inch with the gears you want. 3.50's aren't to hard to find anything lower than that and you'll have a tough time. Ebay also has 3.50 posi centersections for about $150+ shipping. All together you should be able to do this for about $12-1300.
Old Oct 25, 2005 | 05:02 PM
Grims's Avatar
Re: Cheap rear end
would ABS work with this?
Old Oct 25, 2005 | 05:07 PM
Z95m6's Avatar
Re: Cheap rear end
No. You would have to build your own ABS setup, which would run around another $1-150.
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
ModdedNerd
Dec 25, 2014 05:51 PM
