Back End Loose Problem
Old Oct 24, 2005 | 05:06 PM
GHWelles's Avatar
Problem: The back end seems like the axle is loose side to side. The car is fine in a straight line over bumps, but going around corners, and particularly bumpy corners, the back end feels very loose and the back end drops to the back right corner.
I ran over a curb with the back rear tire going pretty fast.
I replaced the springs and shocks and replaced the panhard bar with the SLP boxed bar. I have all new tires and rims. I have the bolt on subframe connectors.
Better but still losse. What could still be loose or broken?
Old Oct 24, 2005 | 06:07 PM
94blackz14.2's Avatar
Re: Back End Loose Problem
I am no expert in this department but I think that it has to do with having a solid rear axle compared to an independent one. Meaning when the one tire reacts to a bump it wants to lift the other one up as well causing the rearende to jump a little. Just a thought.
Old Oct 24, 2005 | 06:15 PM
GHWelles's Avatar
True, but it was not like that before I hit the curb. Now it is abnormally loose.
Old Oct 25, 2005 | 08:23 AM
LWillmann's Avatar
LCA's or their bushings maybe?
Old Oct 25, 2005 | 10:39 AM
GHWelles's Avatar
I have new lca's and bushings and a larger rear anti-sway bar ready to install. I hope that does it. Any other ideas?
jcamaro95lt1
Jan 24, 2015 08:21 AM
Jazsun
Dec 29, 2014 12:14 PM
Hurin
Dec 13, 2014 07:38 PM
