Can't get new pads to fit over rotor...
Old Oct 24, 2005 | 10:24 AM
Kurt Crosbie's Avatar
I compressed the piston back in with the c-clamp, but the pads still aren't making enough room to get over the rotor. What am I doing wrong?
Old Oct 24, 2005 | 10:37 AM
anthony714's Avatar
Re: Can't get new pads to fit over rotor...
you sure the piston fully seated and the pads are seated properly?if so id try a new set of pads cause theres no reason it wont fit.also befor eyou hit the caliper with the c clamp i hope you pinched of the line and cracked the bleeder?the old days of squeezing piston dont cut it with abs since you push a lot of sediment back into the lines and accumilator..fyi
Old Oct 24, 2005 | 11:24 AM
I got it in, but I didn't pinch off the line and crack the bleeder. Since I failed to do so, what do I need to do now?
May 1, 2015 01:14 PM
nikko
Dec 2, 2014 03:43 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
