Data Login with TTS Datamaster
Old Oct 11, 2005 | 06:46 PM
95TAMaddog's Avatar
Question Data Login with TTS Datamaster
I have a 95 TA and I have TTS Datamaster. They told me when I got it that my computer is an obdI but I need a obdII cable. I can't get it to work. I plug it in and the check engine light come on and stays on and the fan stays on the entire time, but I can't get any readings on it. Please help. I need to see what is going on.
Thanks
Hughey Bellue
Old Oct 11, 2005 | 10:04 PM
infinitebird's Avatar
Re: Data Login with TTS Datamaster
Are you plugging it in before you turn the car on? If not try that. Are you sure you have the right port selected in datamaster?
Old Oct 11, 2005 | 10:06 PM
shoebox's Avatar
Did you buy the correct cable?
Old Oct 12, 2005 | 06:31 AM
95TAMaddog's Avatar
I have the obdII cable
Old Oct 12, 2005 | 08:07 AM
shoebox's Avatar
If it is a pure OBD-II cable, it is the wrong one.
There is a special cable for the OBD-I computer with OBD-II shaped DLC.
Old Oct 12, 2005 | 07:35 PM
95TAMaddog's Avatar
where can I get the cable
Old Oct 12, 2005 | 10:39 PM
shoebox's Avatar
Where did you get the one you have now?
http://akmcables.com/
and
http://wotelectronics.com/
are just two places you can get cables. There are lots of others.
Old Oct 13, 2005 | 09:17 AM
95TAMaddog's Avatar
I got it from tts datamaster. It cost 100 bucks
Old Oct 17, 2005 | 11:44 PM
Mean Green Z28's Avatar
considering that datamaster sent you the correct cable, have you checked to see if your computer detects the cable and what COM port it uses? Go to system/hardware and check COM ports to see if it detects the cable and what COM# it is. When you go to record, make sure you select the correct COM# in the record window under setup.
If this doesn't work, kill the sale team at datamaster and get a cable from AKMcables.com for a '95. It's basically a the same cable as the '94 (OBD-I) but with the OBD-II plug. I got the one that has a Y and has BOTH types of connectors 'cos I work with various years.
Old Oct 18, 2005 | 12:35 AM
67fso's Avatar
Try this one for your 95 for $40:
http://www.aldlcable.com/sc/details.asp?item=aldlobd2
Novo
Jun 14, 2016 02:58 AM
93 RedBird
Nov 15, 2015 08:24 AM
Bails098
Aug 17, 2015 05:15 PM
BMX Dad
Aug 3, 2015 09:15 AM
BMX Dad
Jul 27, 2015 02:39 PM
