looking for a 383 CC306 with 58mm tb tune
Old Oct 9, 2005 | 04:38 PM
speedracer69's Avatar
i have tuner cats thing
help!!
Old Oct 9, 2005 | 04:45 PM
Re: looking for a 383 CC306 with 58mm tb tune
Here is some more info
I just need a base tune because my out computer got wiped out.
Its a 383 with ported heads. 1.6rr
58mm TB
G2 Mass Air
42lb ford injectors
no cats, no air pump
it has the comp cam 306
running 45psi on fuel
255gph pump.
I got the tuner cats program and the cable.
Can someone please help
Old Oct 9, 2005 | 10:56 PM
turbo_Z's Avatar
www.madz28.com
www.pcmforless.com
Old Oct 18, 2005 | 12:05 AM
Mean Green Z28's Avatar
I can send you a file for a Lingenfelter 383 with a custom Joe O. cam and heads, not sure if it'll work with all your mods though ... also, if you want it, I'm not responsible for any mishaps if you use it. What you COULD do is, compare the file with your tune and see what you need to change (within reason) to come up with your tune. You'll obviously have have to use your injector #'s and do sometuning on the MAF tables, but you should have an overall idea of where you're going.
I'd suggest getting a scanning software like Datamaster (I like the interface on it) and logging some drives and tune accordingly with the VE/spark/MAF tables. The main thing is to creap up on your final tune, rather than making big changes all at once. It'll take a while, but you'll get the hang of it after a couple drives.
mightymouse383
Jul 20, 2016 07:34 AM
maybe2fast
Mar 26, 2015 08:34 AM
kaoticcamaross
Feb 17, 2015 03:13 PM
Killer94z
Jan 13, 2015 12:06 PM
