Hooker Competition cat-back
I was thinking of using this cat back system because it is fairly cheap, mandrel bent, and appears to be easy to install. I am mostly concerned with air flow but I would like it to sound a little better than stock at least (but definately not too loud). Let me know what you guys think.
Re: Hooker Competition cat-back
It sounds alot better than stock but if your worried about loudness you might want to find some sound clips. It may be too loud for you. I personaly love it but everyone has different taste. On mine I put turn downs instead of having the tips the give you with the kit and it quieted it down quite a bit
I had no problems with the sound level of this... I have an '86 305 firebird and have stock manifolds, at this point, with the hooker supercomp exhaust and a cat delete. The car isn't loud with my setup. Well within legal limits. My '92 camaro, with stock piping, a cat delete, and a flowmaster muffler is considerably louder then the hooker. It's a very unique sound. I'm pleased with it, for a $270 3" mandrel catback.
Sounds like a winner then. Another question, will this exhaust system line up with the end of the hooker competition shorties + Y-pipe? I want to be able to put a straight pipe connecting the two in place of my cats.
I think the end of hooker's Y pipe is only 2.5"... correct me if I'm wrong... You may have to cut the tip off and have a shop weld a 3" pipe between the y pipe and the catback.
I believe the Y-pipe goes from dual 2.5" to single 3". If it was any smaller it would eliminate any potential performance gain from the headers. Also, I would like to keep the shops out of it since they would be required to weld on a cat at the same time.
Mar 13, 2016 03:37 PM
Devinfoote87
Jul 30, 2015 09:54 AM
