I can't get the intake manifold off
Old Oct 24, 2002 | 09:40 PM
1990 NA 300ZX's Avatar
I unbolted all the bolts (3.4 camaro) but it still won't come off,also the fuel rail won't come off, what am i doing wrong? That piece of **** haynes manual is worthless it does not give compleat detail, i should have bought a chiltons can someone help please?
Old Oct 24, 2002 | 10:04 PM
stagen's Avatar
If this is the first time you have taken it off or it has been removed then you need to use a little muscle. The gaskets are well worn on there.
For the fuel rail releive the pressure first, take off the two screws on top, then you'll need to possibly give it a little prying with a long screw driver under the main rail. Your o-rings are probably hard as a rock by now keeping it tight.
Upper Intake plenum:
remove TB and accelerator cables etc..
remove all the wiring harness etc, move aside
on the left (passenger side) remove wire and module from the side of the plenum
Remove bolts
lift plenum
Old Oct 24, 2002 | 11:18 PM
Tiago's Avatar
gotta put some muscle into it!
Old Oct 24, 2002 | 11:38 PM
stagen's Avatar
LOL - -kind of like that bell housing bolt of Jeff's
Old Oct 25, 2002 | 12:19 AM
Tiago's Avatar
Old Oct 25, 2002 | 12:26 AM
nikkev's Avatar
Talking
Block of wood and a big hammer But make sure all the bolts are out first!
Kevin
Old Oct 25, 2002 | 12:37 PM
Talking
Ok so its muscle, wood, and a big hammer got it
Old Oct 25, 2002 | 01:16 PM
stagen's Avatar
Make that a BFH and your set
mightymouse383
Jul 20, 2016 07:34 AM
69z-28
Jan 29, 2016 10:46 PM
HarleyZ28
Oct 5, 2015 06:23 AM
Elcojoe
Nov 17, 2014 10:27 PM
