Parking Brake not working??
Old Sep 15, 2005 | 01:01 PM
95_z28_4_Ivan's Avatar
Does anybody know how to adjust this problem ??
Thanks..
Old Sep 15, 2005 | 01:30 PM
GT KILLER's Avatar
Re: Parking Brake not working??
Well what is it doing? Does the lever not go up? Does it go up but just falls right back down again?
Need some more info.
Old Sep 15, 2005 | 01:56 PM
That's right...
well the lever goes all the way up & stays up but it does not stop the car !!!
Old Sep 15, 2005 | 02:40 PM
93LT1355's Avatar
Sounds like you need to adjust the cable and make it tighter.
Old Sep 15, 2005 | 03:01 PM
Adjust the cable , kool
How do I do that ?
is there a link you could forward or anything..
thanks man...
Old Sep 15, 2005 | 09:21 PM
OBE1 95Z28's Avatar
There's no adjustment on the cable that I know of. First verify that the cable and lines are in place (runs above the driveshaft along the floor pan). Also verify that you still have "meat" on your rear brake pads. If the cables and balancer are "in tact", and there's meat on your pads, there's an adjustment screw on the rear brake caliper. Here's a link to Shoebox's site showing the adjustment:
http://shbox.com/1/adjparkingbrake.jpg
Old Sep 15, 2005 | 09:25 PM
sw89lt1's Avatar
mines like that too but its because my brake shoes are wornout. you should check em.
Old Sep 16, 2005 | 09:57 AM
Great thank you much, & I did change the brake pads about 3 months ago so they should be ok, But that Link should take care of that prob.
Thanks again.
Old Sep 17, 2005 | 04:48 PM
dutss707's Avatar
I thought I had same problem, after awhile changed complete Braking system et.
I put PB on then gave it some throttle, and car would move, so I thought system did not work, however., the cable activate calipers, and when turn off engine, car rolls slightly into the brakes, not the auto. trans, So do you figure it does not work because you are also giving it throttle and it moves, instead of letting the car roll slightly into the PB. and lock. Try it on an incline. at least this was my experience, I also thought as with previous cars that when you put PB on car would stay there while increasing throttle..not with this car....Theo
jb4xx
Feb 2, 2015 10:00 PM
Gtpguy
Jan 26, 2015 04:50 PM
Brake_L8
Jan 20, 2015 09:44 AM
Red97LT1
9
Dec 17, 2014 06:13 PM
Matt-01-SS
Aug 2, 2002 04:05 PM
