Will this amp work for this?
Old Aug 21, 2005 | 09:11 PM
chris96camaro's Avatar
I have a kenwood kac-929, rated at 460 rmsx1 @4ohms bridged. My question is can i run a 12w7 off this amp until i can get a bigger wiring kit installed to hook up my 1000/1? W7 can either be wired to 3/1.5 ohms, and my amp can be run at 2 ohms or 4 ohms? And it can be bridged at 4 oohms...will it work, and if it will how would i wire it, just bridge it and run it like that?
Old Aug 22, 2005 | 04:16 AM
LS1 RULZ's Avatar
Re: Will this amp work for this?
If the sub is 4ohms and the amp is bridged then yes, you can use that amp with that sub. If the sub's impedance (ohms) is lower than 4ohms then you cannot bridge that amp and use it with that sub. The amp will more than likely go into protection mode whenever you crank up the volume because the impedance is too low.
Old Aug 22, 2005 | 05:29 AM
Can i use only one of the channels to power the sub?
Old Aug 22, 2005 | 06:45 AM
LS1 RULZ's Avatar
Yes, but why would you want to?
Old Aug 22, 2005 | 04:37 PM
Just to test that the sub works and is not blown when i get it, until i can run the 4 gauge to run the 1000/1...
Old Aug 23, 2005 | 11:52 AM
Fuji_LT1's Avatar
dont run a single channel to the sub its pointless, I agree with the post above, if you have the option to run a w7 then dont use a kenwood amp. kenwood is nice entry level stuff, but if you want real performance go to a 1 ohm stable amp(kicker,PPI,high end rockford, etc...) that way your not fully maxing out the resistance load and have less of a chance of damaging your amp or sub.
Red Hawk 94
Mar 18, 2019 04:03 PM
Jason Short
Jan 19, 2015 06:34 PM
NewsBot
Jan 8, 2015 11:29 PM
Rino1313
Jul 19, 2002 04:31 PM
Rino1313
Jul 18, 2002 05:16 PM
