No Injector pulse, help!
Old Aug 17, 2005 | 09:42 PM
NeoSNK's Avatar
My dads buick with a 3.3 has no injector pulse, I checked with a noid light. It will run if you spray starting fluid in. It has a new fuel pump, new ecm, and new ignition module. It has 40psi at the fuel rail. Could it be the fuel pressure regulator? Its a 92 skylark.
Old Aug 17, 2005 | 09:43 PM
crasher88's Avatar
Re: No Injector pulse, help!
check to make sure the cam and crank shaft sensors have good out put signal.
Old Aug 17, 2005 | 10:25 PM
NeoSNK's Avatar
Theres a sensor on the crank but that controls spark right?
Old Aug 17, 2005 | 10:38 PM
crasher88's Avatar
it also coltroles injector pules. The cam and crank sensors send a signal to the pcm. It lets the computer precisely know exactly where the egnein is, and what I mean by that it lets the computer know where each piston is in relation to its 4 stroke cycle, and it also lets the computer know where cam shaft is. So it can precisely know when to open each injector and allow the most accurate advance for spark timing.
G-BODYT56
Jan 14, 2022 11:14 PM
magman
Apr 15, 2016 03:08 AM
autoxr166
Sep 25, 2015 04:21 PM
form94
Sep 23, 2015 07:30 AM
95blkss
Sep 22, 2015 03:18 PM
