weird oil pressure problem
Old Aug 4, 2005 | 11:36 PM
cashmoney25's Avatar
hi
i am having a weird oil pressure problem on my 383. its brand new, cola crank, eagle rods, JE pistons. moroso anti-cav pump, stock oil pan.
Everything is fine, cept that if I rev it out to say 5k (not even full throttle, just 1/4 throttle) and let off, oil pressure drops to zero - and stays there- for several seconds. oil pressure comes up instantly on cold start, and it always ok just cruising around. it is also ok under braking (ruling out the pickup falling off, which i welded anyway)
if I just rev it un netural, its fine. so it seems to be either acceleration or load based.
the whole motor is new.
any ideas???? I am about to drop the pan and check stuff out...
Old Aug 4, 2005 | 11:44 PM
sniffin94's Avatar
Re: weird oil pressure problem
my guess is the pickup tube
Old Aug 5, 2005 | 01:10 AM
sleeperz28's Avatar
Check basics:
Oil level
assuming your baffels work proparly in the pan
Then pump tube as the other guy said...if that ok
If everything is draining back to the pan ok then...somewhat rare but your not sucking the pan dry are u. My machinist said sometimes when they ran a big block pump on a small block it would suck the pan dry...
Old Aug 5, 2005 | 01:46 AM
iwon's Avatar
1st establish correct oil pressure and DO NOT run the car untill you know for sure, drop the pain check the pickup etc.
Old Aug 5, 2005 | 02:09 AM
Victory Racing's Avatar
Did you check how far the pick-up is from the bottom of the pan?
Old Aug 5, 2005 | 02:56 AM
CamaroSS30thAnn's Avatar
do u have a high pressure pump? if so u can be draining the pan?
Old Aug 5, 2005 | 10:04 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
my guess was going to be the pickup tune to pan distance, but its odd it doesnt do it when just reving in gear.
I guess maybe the oil demand for the motor increases with load?
Old Aug 5, 2005 | 11:45 AM
FASTFATBOY's Avatar
Cam bearings, been there, done that.
Old Aug 5, 2005 | 01:47 PM
SStrokerAce's Avatar
Do you have a windage tray or did you toss that and now you are running the stock pan without the stock tray or a aftermarket one....
If you add oil it will make the problem worse, or a high volume pump. Just put a windage tray back in there if it's not now and the problem will be solved.
Bret
Old Aug 6, 2005 | 03:24 PM
P's Avatar
P
Aye, chalk up another for cam bearings. I just went thru that.
P
Old Aug 6, 2005 | 04:43 PM
1racerdude's Avatar
How many miles does it have on it?
Old Aug 6, 2005 | 08:22 PM
Motor has like 5 miles on it, all brand new(including cam bearings)
no windage tray, standard vol pump,
Old Aug 6, 2005 | 08:35 PM
1racerdude's Avatar
Put the tray back in and look for any silver and copper spects in the pan while ya got it off.
Old Aug 6, 2005 | 10:51 PM
Blownbird355's Avatar
Stock pan? If so oil could be climbing rear of pan if thats the case you need the moroso piece that goes between oil pump and block. It acts like a dam preventing oil from climbing under acceleration.
Old Aug 7, 2005 | 02:43 PM
BINGO! and it's a stock pan to boot probably.
08-05-2005 01:47 PM
SStrokerAce Do you have a windage tray or did you toss that and now you are running the stock pan without the stock tray or a aftermarket one....
Bret
Throw even the stock cheap windage tray in there and you should solve that problem, it's not cam bearings unless the cam was out of spec for journal size.
Bret
