Swapping ET streets to break them in better?
Old Aug 1, 2005 | 06:12 PM
Slayn's Avatar
Just got my ET streets mounted (not the radials) and one of the owners of the shop next door (he has a 9 sec stang) was swinging by and recommended swapping the tires to the opposite side after a couple runs to help break them in, so the tires get to wrinkle both ways a few times before you leave them on a certain side... Seems to make alot of sense to me, just wondering how many others out there do that.
Old Aug 1, 2005 | 06:25 PM
Kyle@CSS's Avatar
Re: Swapping ET streets to break them in better?
I always kept them facing the same way. I even marked them so I wouldnt mix them up.
Old Aug 1, 2005 | 06:52 PM
Stephen 87 IROC's Avatar
From the MT web site. It's in the FAQ.
Q: Should Mickey Thompson slicks be rotated side to side?
A: This should only be needed if you are getting excessive furring, shredding or tearing of the tread rubber. Mickey Thompson suggests that you rotate every 25-30 passes if needed. Larger tires and high horsepower cars may need to rotate more often.
Victor Lamb
Aug 26, 2017 02:52 PM
alex5366
Mar 27, 2015 03:30 PM
cmyname1
Feb 19, 2015 08:38 PM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
