Can someone please look at a datamaster file, PLEASE.
Old Jul 27, 2005 | 07:18 PM
Silvershark's Avatar
I have a log of a datamaster file and I need to figure out what my running rich problem is being caused by. I just stuck in new delco 02 sensors last night. The 02 sensors fixed the weird cam surge and bogging issue, however now my car is just running insanely rich.
Thank you.
Old Jul 28, 2005 | 08:03 AM
LWillmann's Avatar
Re: Can someone please look at a datamaster file, PLEASE.
I don't have a way to read a datamaster file.
Is it reading rich, or is it reading lean?
If it's reading lean, and adding fuel, when you think it shouldn't be, check for vacuum leaks or air leaks after the MAF sensor, and check for exhaust leaks before or close to the o2 sensors.
If it's readin rich, and pulling fuel out, I'm not sure what to say.
Some cars need the MAF table adjusted to match the actual performance of the car.
It's also possible you have a bad MAF, see if you can swap with a friend or something to see if that makes a difference.
My car was reading really lean and adding lots of fuel, replacing the MAF fixed that for me.
You might even try just cleaning the MAF with electrical contact cleaner.
Old Jul 29, 2005 | 08:36 AM
If he posts them in ".csv" format (export as .csv) you can open them with Excel.
I've just got so many to look at now, that it might take me a week or so to get to any new ones.
Old Jul 29, 2005 | 02:47 PM
radik's Avatar
Maybe once your provide a link to the log people might help..
Old Jul 29, 2005 | 08:18 PM
here is a link to the .csv file.
http://www.akgaming.com/~kendall/files/silvershark.csv
Thanks!
Old Jul 29, 2005 | 10:23 PM
Can't connect.
Old Jul 29, 2005 | 10:45 PM
markinkc69z's Avatar
It would appear that you have a large exhaust leak on the driver's side. At least in my inexperienced opinion.
Old Jul 29, 2005 | 11:52 PM
Hmm, I will double check, however all exhaust parts are new.
Old Jul 30, 2005 | 04:38 AM
MyTMous's Avatar
I agree with the one above, the readings on the left side O2's are very low,
I see where it goes up but then back down. So it does work every once and awhile. which would rule out plugs or wires. opti would show on both sides,
so it looks like it is getting a lot of air inside the before the O2 on the drivers side.
check the wires also as you could have some that are arching most of the time. but I doubt it.
I had the same kind of issue, but mine was right side and low all the time.
found 3 cut plug wires.
Old Jul 30, 2005 | 09:51 AM
Finally got it open.
You're not recording anywhere near the amount of data you need to do a decent analysis. I don't see:
RPM
MAF
system voltage
coolant temp
inlet air temp
cell #
pulse widths
Without the rpm and cell #, its almost impossible to see anything meaningful. Why aren't you recording those?
TPS voltage is definitely on the high side at 0.92V closed throttle.
Both O2's should read approx 450mV when you turn the key on. Your left sensor is screwed up. It shows up as screwing up the long term corrections, with values as high as 160. Although if I had to guess, that will be Cell 17, because its always closed throttle coasting when the really high values show up. See why its impossible to do anything meaningful without the Cell #?
Right O2 stays stationary for 90 seconds after startup.... like the heater isn't working.
Aroung line 990 you close the throttle and the left O2 drops like a rock to the 80mV range.
Did you reset the PCM before the log? LT's start at 128 in open loop. When it finally goes into closed loop after about 200 seconds, the long terms start "learn". You shouldn't reset the PCM before a data log, if that's what you did. We need to see the fully developed lont terms, resulting from a long period of driving.
Also something screwy with MAP and TPS. Around line 245 you're seeing a MAP of 92.6kPa which would indicate the throttle is almost wide open, but your TPS voltage is only 1.08V indicating the throttle is barely cracked open. It happens later on in line 818 for example when yousee 97.4kPa, but TPS is only 1.53V.
Have you checked the TPS sensor with a volt meter? You would want to see 0.50-0.70V at closed throttle, and about 4.5V at WOT, with a smooth transition over the full range from closed to WOT.
There's one point (line 941) where you are showing 60deg of spark advance.... must be a glitsch in the data.
You've got to set the scanner up so it records the required data.
Old Aug 1, 2005 | 07:37 PM
I have a rip about the size of a dime in my throttle body elbow, perhaps that is why it is showing the TPS voltage very low but in fact a lot of air is passing? I will try and duct tape the air hole to see if it makes a difference. I have a new elbow on order, but it is taking time and money to get the car where it needs to be.
I am also going to try and put the car in open loop mode only and see how it runs.
Old Aug 1, 2005 | 08:45 PM
Your car would be running lean then because you have unmeasured air entering the engine. That could cause accelleration hiccups. Do exactly as Injuneer says and check your tps signal with an analog (needle) voltmeter so you can see if there are any signal dropouts. I assumed as there were no longterm counts that the problem just happened which reinforced my exhaust leak theory.
Old Aug 2, 2005 | 08:56 AM
A leak in the intake elbow will drive the long term corrections up, but its not going to affect the TPS voltage readings or the MAP readings. Those two are not consistant.... It isn't likely you would see close to barometric pressure in the intake manifold, when the throttle is barely open. Either the MAP sensor or the TPS sensor is providing bad data.
Old Aug 3, 2005 | 12:14 AM
Ok, I went ahead and put the car in open loop mode only today, and man it runs 90% better. It is like a new car! The gas milage is also incredibly better compared to before. I imagine I was getting 3mpg before.
Here is a log file of my car running open loop mode. I also patched up the intake leak.
www.akgaming.com/~kendall/files/lt1.csv
Thanks again guys for all the help.
I emailed Ion today and hopefully he can do an openloop tune of some sort for me.
Old Aug 3, 2005 | 12:44 AM
Ok, I am also curious. I have few different members from this board's tunes that they use on their cars... These are well versed people from what I can tell via the board and their VE tables are adjusted. Mine are not adjusted at all from the Stock VE Tables.
For example, Atljar's. I was just curious why this is. I also have a pcmforless tune that I was comparing too and he adjusts the VE tables as well.... Could perhaps not adjusting the VE tables from the stock values cause my weird problems in closed loop operation?
I have all new parts in the car, if you dont believe me please view my website and you can see all what has been done to this motor, it was not half assed and I dont want to blow 8k down the drain.
Thanks for the input.
