Difference between mild steel and chromoly?
Old Jul 24, 2005 | 10:54 PM
roguedriver's Avatar
Whats the difference between mild steel and chromoly, say with a K-member for example. I would assume chromoly is stronger, but if so, how much stronger and how do weights compare? Thanks.
Ken R.
Old Jul 24, 2005 | 11:12 PM
Re: Difference between mild steel and chromoly?
Generally, chrome moly is used to reduce weight. Because its stronger, you can use a thinner wall section in the tubing, reducing the weight, while keeping the strength the same. But chrome moly is difficult to weld correctly.
Old Jul 25, 2005 | 07:15 PM
Thanks for the info.
Ken R.
SergheiS
Jul 5, 2015 03:27 AM
Jasonz28camaro
Jun 7, 2015 09:14 PM
Jasonz28camaro
West South Central
Jun 7, 2015 09:12 PM
KamikaZ28
May 28, 2015 12:45 AM
