Spohn adjustable torque arm install??(PLEASE)
Old Jul 22, 2005 | 09:32 PM
always faster's Avatar
I receive mine today but it came without install instruction.I know the basic to put it on the car, thats not a problem.
But there s 2 big bolts on the pieces that connect on the cross member.One of them pass trought the polyurethane bushing and the other one keeps the pieces together.Do i have to tight these bolts very hard or should i left a small play??
And how do i adjust it with the angle finder???
And is there anything that i should know?
Thanks
Old Jul 23, 2005 | 12:05 AM
Re: Spohn adjustable torque arm install??(PLEASE)
Send him an e-mail on the "tech" line.... he should be able to send you the instructions. Mine came with several pages.
Old Jul 23, 2005 | 11:55 AM
I ve found this :
http://www.go-fast.org/z28/pinionangle.html
Is this the good way?
Thank you
Old Jul 25, 2005 | 12:54 AM
Bud M's Avatar
Yes, those instructions for setting pinion angle will do the trick.
Old Jul 25, 2005 | 06:07 PM
Thank you
Old Jul 27, 2005 | 01:00 PM
Bayer-Z28's Avatar
Tighten the rearend bolts and tighten the mount. Leave everyting else loose. After you set the pinion angle, then tighten the side bolts. I used an impact gun on the rear and some wrenches on the sides.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
canbaufo
May 5, 2015 03:43 PM
Jason Short
Jan 19, 2015 06:34 PM
