Will headers last here in Texas if they are not Jet-coated?
Old Oct 21, 2002 | 03:22 PM
ucrazymonkey's Avatar
I have been driving myself crazy trying to buy headers. I want to buy either Hooker Lt's or Shorties that are Jet-coated. The only problem is that when I call Jet-Hot they have neither in stock and it will take at least 2 weeks to get here. I am out a car right now and can not afford to be without a car starting next week.
So leaves me to my question. If I buy headers that are not coated how long would I have before they rusted away? What about using the heat tape for right now? Any suggestions? Im in a tight spot. Thanks Nathan
Old Oct 21, 2002 | 06:57 PM
BLK97Z28's Avatar
I've had mine on for a year and before that, some other guy had them on his car for a while here too. Mine are uncoated and, other than getting hotter than a **** in 5 seconds, are perfectly fine. I think the heat will burn off the water, plus hookers are made from good steel so they will prolly outlast most of your car.
Old Oct 21, 2002 | 07:13 PM
JurisAg02's Avatar
mine arent coated, they get ugly quick but if it isnt a show car save you the money and get em uncoated...I havnt seen a diff in performance...I have driven cars with both uncoated and coated with similar kind of mods/engines....no diff whatsoever...IMO coating is overrated like most "bling bling" junk you see on high perf car parts nowadays
Old Oct 21, 2002 | 07:16 PM
BLK97Z28's Avatar
You're right, they don't make a difference for the most part. But they do heat up faster uncoated and have a tendency to burn wires (shut up Rick) if you're not careful. But I fixed all my burn problems and they work perfectly fine. I say get uncoated ones and save yourself the $150-250
Old Oct 21, 2002 | 11:46 PM
mcss383's Avatar
Yes they will last. A friend in Waco has uncoated TES on his Monte that have been on there for 5yrs I believe and no problems. Granted they don't look as nice as my Jet-Hot coated ones but they last just fine.
Old Oct 22, 2002 | 02:16 PM
JurisAg02's Avatar
Can you prove the temp theory? Has anyone actually measured the temps under the hoods of two cars with uncoated and coated....I am sure it makes a SLIGHT difference...but I would like to see ACTUAL NUMBERS that can justify the expenditure...
Rick
Old Oct 22, 2002 | 06:45 PM
BlackHawk131's Avatar
Rick
contact jet hot and find out. you must remember that anything taht removes heat helps, but how much heat?? I know that I like mine coated becuase I like the look, that matters to me but I don't believe there is a performance gain going either way.
I still will argue though that the coating does help on the heat and we can prove by seeing which ones cool off faster!!
13qtr
Jul 19, 2015 05:30 PM
Strick
Jul 14, 2015 07:28 AM
mrwz28
Jul 8, 2015 09:11 PM
