putting old stlyle heads with my Tpi
Old Jul 16, 2005 | 10:22 AM
Lynk's Avatar
I have old stlye bolt pattern heads that I want to hook my TPI up to, I know it can be done but I'm not sure how much somthing like that would cost. I would go with new style heads except they don't make a head with big enough valves or enough clearance for my cam. So if you have ever done this please let me know about how much it will cost.
Old Jul 16, 2005 | 11:44 AM
iansane's Avatar
Re: putting old stlyle heads with my Tpi
The bolt holes just at the wrong angle on the manifold. It wouldn't be hard for a machine shop to trim the boses down and straighten out the holes.
Old Jul 16, 2005 | 05:16 PM
Lynk's Avatar
Thanks I will look into that.
Old Jul 16, 2005 | 08:06 PM
Dave89IROC's Avatar
or get the intake base from a 85 f-body or late 80s vette w/aluminum heads, these all used the old style bolt angles
Old Jul 16, 2005 | 09:39 PM
Lynk's Avatar
I pulled the motor out of an 87 trans am, don't really want the motor just the tpi, but I don't know if the motor is a 305 or a 350, the casting numbers are gone, the blocks been decked. It has a small balancer on it so I would guess its a 305, but I guess I'll have to pull a head to be sure. Seems how the motor has been rebuilt and is in running condition I am almost tempted to throw it in my camaro just to see what it will do. But I think I'll wait to blow the motor thats in it first. Then I'll build my 377
Old Jul 17, 2005 | 06:26 AM
Dave89IROC's Avatar
the casting number should still be there, look at the bellhousing flange, it should have the size cast right into the drivers side, 5.0L=305, 5.7L=350
the stamping number is probably gone after decking, but not the casting number
Roadie
Feb 16, 2015 10:34 AM
InfernalVortex
Jan 17, 2015 09:35 AM
capebuf
Jan 13, 2015 07:22 PM
NewsBot
Dec 28, 2014 06:20 PM
Lederman1976
Nov 30, 2014 05:21 AM
