Need Valvetrain Help. Located in Eastern Ohio.
Old Jul 4, 2005 | 12:57 AM
usa1racing's Avatar
I am building a new motor for my Camaro, and need to check valve-to-piston clearance with TRW domed pistons. I also need to check pushrod length. I need 1 rocker arm and a checking pushrod. I want to use 1.6 rocker arms, and I can use either a 3/8" or 7/16" stud. If someone can help me out by letting me borrow, or meeting me here in Ohio to check the clearances and pushrod length, I'd really appreciate it.
Does anyone have expeirience with these pistons? They're part # 2304, with a 0.125" dome installed 0.023 in the hole. I plan to use a thicker head gasket. The cam is Comp Cams part #12-622-9, and it has 0.500/0.510" lift with 1.5 rockers. With 1.6 rockers, it would be 0.544/0.533".
Next question is about rockers. I'm considering Harland Sharp, Summit, and Scorpion. I know the Harland Sharp's are good. Anyone have ideas on the others, or another brand I should be looking at?
HectorM52
Jul 30, 2017 11:46 AM
69z-28
Jan 29, 2016 10:46 PM
Scorch1
Jun 30, 2015 11:24 PM
Chet1185
Parts Wanted
Mar 15, 2015 04:29 PM
MyShibbyZ28
Feb 14, 2015 12:05 PM
